08-17-2010, 08:52 PM | #1 |
Active Member
Cut it, beat it or Replace it lowered front end dust shield
I dropped the front end of my truck and discovered tonight it was not my brakes dragging but my rotor is rubbing against the dust shield
See the attached photo for the area of concern. Has anyone else ran into this situation? These are ece drop spindles
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
08-17-2010, 09:15 PM | #2 |
1969 Short, Fleet, and Beat
Re: Cut it, beat it or Replace it lowered front end dust shield
Bend that baby back.
08-17-2010, 10:06 PM | #3 |
I don't think those dust shields are bent right. I don't recall that flat spot on my stock shields. You sure those are not a later model? I will have to take a look at mine tomorrow in the daylight.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
08-17-2010, 10:38 PM | #4 |
Are those ECE dust shields? The ones I got from them don't have that cut out in them.
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. |
08-18-2010, 01:48 AM | #5 |
Big Red - Now its a SWB!
a big hammer will solve all of your problems....or at least this one.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
