08-19-2010, 04:40 PM | #1 |
Drop shackles
Just wondering if anone has had any luck with the drop shackles and how hard they are to install ? Being from canada I know that the bolts are going to be rusted in pretty good, does anyone have suggestions on how to take them out without destroying anything?
08-19-2010, 05:01 PM | #2 |
Re: Drop shackles
pre soak the bolts you are going to take off w/ some penetrating oil or wd40. id hit them up a few times a couple days before you are going to take them off
1986 LWB C-10 305/th400 Daily Driver and beer runner |
08-19-2010, 05:36 PM | #3 |
On a budget like Fred Sanford
Re: Drop shackles
If your bolts are as bad as mine were, don't even bother with the penetrating oil. My bolts were frozen to the steel sleeves in the bushings, so I had to cut off the bolt head on one side and the nut on the other with a cutoff wheel to get the stock shackles out. That's the only hard part though, smooth sailing after that!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 08-19-2010 at 05:37 PM. |
08-19-2010, 05:45 PM | #4 |
Re: Drop shackles
CHEVY ONLY |
