08-20-2010, 07:43 PM | #1 |
Lowering rear on 48 question
Does anyone have pictures of the rear stance on a 48-54 truck as low as you can go with stock springs? I was thinking a 3" block was about all you can do without needing to notch the frame. If you have any pictures please post and also the tire size. Thanks for your help.
08-22-2010, 12:52 AM | #2 |
Re: Lowering rear on 48 question
This one was at a local show last year and I am pretty sure it has a stock drivetrain and suspension. I didn't look under it though.
08-22-2010, 03:39 AM | #3 | |
Ray Last edited by raycow; 08-22-2010 at 03:41 AM. |
08-22-2010, 10:37 AM | #4 |
My axle is already on top of the spring with a 10 bolt rear end. I am in the process of putting the truck together and looking at tire setups. I will probably need to get the tires on to determine the block size I need. I was just wonder about what the max was in case I need to get to that block size. I am guessing about 3" is the max, but just thought I would check.
Tags |
rear stance |
