Old 08-22-2010, 10:32 AM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Question hood hinges ?
all,
i am wanting to seperate the springs from my hood hinges & would like to know the best/easiest way to do this?? i would prefer to not poke my an eye out!!
any help would be greatly appreciated!!
thanks!!
ps. if it matters i have a '72 chevy hood
rodstored-72 is offline   Reply With Quote
Old 08-22-2010, 10:40 AM   #2
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
Re: hood hinges ?
When they are in the open position, there really is not to much spring pressure on them. Just pull and move to the side that they will come off of. they won't ping pong around the garage.
If everything is still on the truck make sure someone holds the hood open for you!
Looking for all Montana members. PM me or send friend request.http://www.67-72chevytrucks.com/vboa...36#post3813336
MT71c-10 is offline   Reply With Quote
Old 08-22-2010, 10:45 AM   #3
johndawelder
johndawelder's Avatar
Re: hood hinges ?
Don't have them powder coated like I did. The heat takes the tension out of the spring and it won't hold the hood open.I ended up sand blasting a pair and painting them.
johndawelder is offline   Reply With Quote
Old 08-25-2010, 01:25 PM   #4
bmfpeterson
bmfpeterson's Avatar
Re: hood hinges ?
man I was going to do that! glad i read this. can you powder coat the hinges and order new springs????
thanks
bmfpeterson is offline   Reply With Quote
Old 08-25-2010, 01:48 PM   #5
dznucks
dznucks's Avatar
Re: hood hinges ?
i use a big a$$ flat head screw driver to get them on and off.
its alittle scary, but as mentioned above, they are not going to take off flying on you.
dznucks is offline   Reply With Quote
Old 08-23-2010, 03:22 PM   #6
rodstored-72
chevy truck fan
Re: hood hinges ?
mt71 c10,
thanks!! that is what i was wanting to know.... & yes i will have someone to hold the hood!!(lol)
Old 08-23-2010, 03:24 PM   #7
rodstored-72
chevy truck fan
Re: hood hinges ?
johndawelder,
thanks for the info! would you or anyone know if you can "cad plate" them?? i imagine i will just do like you & paint them.....
thanks!!
Old 08-23-2010, 03:31 PM   #8
POPO1984
POPO1984's Avatar
Re: hood hinges ?
I like the CAD idea.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 08-23-2010, 07:06 PM   #9
johndawelder
Re: hood hinges ?
I built a fixture that had a hydrolic jack in the middle and a spring on each side.When I jacked it up , the springs " spred " apart.I then blasted,primed and painted them.After they were good and dry I put em' back on the powder coated hinges.That was 10 yrs ago ,they still look great.
Old 08-23-2010, 07:21 PM   #10
gkesseru
gkesseru's Avatar
Re: hood hinges ?
I use a brake spring tool. I tried just screwdrivers and it was no-go.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 08-24-2010, 05:38 AM   #11
Zeke
Active Member
Re: hood hinges ?
easiest way to get them off is put thick washers between the coils with the hood part way down then when you lift the hood they will come right off. Putting them back on I used a small come-a-long between two fence posts and stretched just far enough so they would go on the hinges, used pieces of wood to protect the paint. Put them on closed the hood the the wood fell out, springs on.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 08-25-2010, 06:18 PM   #12
bigsnookmaster
bigsnookmaster's Avatar
Re: hood hinges ?
Good idea!
bigsnookmaster is offline   Reply With Quote
Old 08-25-2010, 10:40 AM   #13
rodstored-72
chevy truck fan
Re: hood hinges ?
ZEKE,
Thanks for the reply. i will try that this weekend or the next...(LOL!) i think i have the idea.... though i may ask for follow up information! (LOL!!)
THANKS!
Old 08-25-2010, 12:15 PM   #14
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: hood hinges ?
One of the truck rags had an article about removal and they used wrenches, like the suggestion for using washers.
Member Nr. 2770
Old 08-25-2010, 07:19 PM   #15
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: hood hinges ?
I used the hook on a tie down strap to hook onto the spring then I wrapped the strap around my hand to get a good grip then I just pulled enough to stretch it then off to the side. To paint it I backed my truck up by a tree then used two ratchet tie downs (one on each side of the spring to the bumper and then to the tree) to pull the spring open enough to paint the whole thing
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
