08-23-2010, 02:05 AM | #1 |
? regarding rear 5" drop coil
Hello all, I am fairly new to this forum and have to post my first thread.
Today I installed new 5" drop coil springs and new shocks I bought from Brothers on my 72 2wd step side. My question is this... Why did it only drop the truck 3" on one side and 2.5" on the other? (should get 5" lower, right). I mounted the springs first then the shocks,Could I have stretched them when I jacked up the truck to mount the shocks? I have over 4" of travel between the axle and frame and the springs measure around 8" tall mounted. Any advice is greatly appreciated. Last edited by bamabronc; 08-23-2010 at 02:07 AM. Reason: left out some info |
08-23-2010, 02:17 AM | #2 |
Moderator
Re: ? regarding rear 5" drop coil
What was the condition of the springs that you replaced? If they were the original OEM springs, being 40 yrs old, they will sag over time/use. The 5" drop is based on the original ride height.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-23-2010, 05:50 AM | #3 |
did you install an adjustable panhard bar? did you install new trailing arm bushings and panhard bar bushings?
08-23-2010, 06:03 AM | #4 |
70+ ( Old Skool Club )
Should you install new panhard bar and trailing arm bushing when you lower a truck? Should you do control arm bushing if you add dropped spindles and front springs?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-23-2010, 06:57 AM | #5 |
panhard is needed to correctly center rearend, yes you can crabwalk down the road off kilter if you want// to work on suspensions CHEAP CHEAP and ignor worn out 40year old parts aint bright and doesnt enhance your ride
08-23-2010, 07:17 AM | #6 | |
The post-measurements were LR=31 1/4" & 30 1/2". The truck already has an adjustable panhard bar, but havent adjusted it yet. I also have 2 1/2" drop spindles with 1" drop coils to add to the front... have not installed yet. I also have 235x75x15 tires. A comparison of other members' hieght with the same 5" drop coils could help. |
