08-23-2010, 09:37 AM | #1 |
1972 C10 - Easy Lowering Options?
I'm pretty sure I have a couple ideas out there but lookin for options.
This truck will eventually be bagged but I want it lowered and slightly tuckin until then. I figured I could trim or heat the front coils to lower the front and the back maybe just pull a leaf out of each of the springs? Thoughts/suggestions? |
08-23-2010, 10:30 AM | #2 |
Happy to be here
Re: 1972 C10 - Easy Lowering Options?
DO NOT heat your coils. You will find that to be a very negative topic on here. You can cut your front coil. The starting point seems to be try one full coil and see how it sets. For the rear, since you are leaf spring you can remove the thick overload, and possibly some of the others from the pack. You will want to remove some and see how it sets.
08-23-2010, 10:39 AM | #3 | |
It will go from this straight to bags which is why I mentioned heating them. I'm aware of how they settle amongst other things but thanks for the reply. When you say thick overload, you must be referring to the big one on bottom right? |
08-23-2010, 11:39 AM | #4 |
Redefining LowBudget
do a flip on the rear and cut 1 1/2 off the front.....your never going to get it to look right with those rubber bands on it
08-23-2010, 11:42 AM | #5 |
08-23-2010, 11:48 AM | #6 |
no put your axle on top of your springs....or you can flip the hangers theres lots of ways
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
08-23-2010, 12:46 PM | #7 |
jst use the search at the top I'm sure you'll find tons of info on it
08-24-2010, 01:01 PM | #8 |
I'll figure it out, thanks for the replies.
