08-23-2010, 05:33 PM | #1 |
drive shaft ? 67 C10
I am working on doing a engine and transmission swap in our 67 C10 and wondering if anyone might be able to anwser a question for me? I was wondering if going from 250L and 3 speed to a 350 700R in a 67 C10 what length should I need? I am curious buddy has couple drive shaft laying around. Thanks Brandon
08-23-2010, 08:45 PM | #2 |
Re: drive shaft ? 67 C10
It is best to take a measurement after the engine is installed. V-8's can be installed in two seperate places. Some prefer the spot closest to the firewall the same as a 4X4 others like the stock location closer to the front using a stock rad shroud. Other factors are if lowered, using a 2 piece shaft with support mount, 6 or 8' bed etc. So it's very hard to come up with a measurement with so many factors involved.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
