08-23-2010, 11:39 PM | #1 |
Posi's Auburn or Eaton?
I 'm thinking of getting a posi or rebuilding my open rear. Which posi do you guys like and why?
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
08-24-2010, 06:10 AM | #2 | |
Re: Posi's Auburn or Eaton?
Eaton, because it's rebuildable. The Auburn unit uses "cone-type" friction material which actually wears into the case. It may last as long as you own the truck...but then again maybe not. Why take the chance?
With the Eaton, if the clutches wear to the point of excess slippage, you can replace them easily. If you are just changing carriers, we can walk you through that. But if you intend to get deeper into this axle, seek professional help. It is not a simple "bolt together" thing. It's a wise investment.....with a warranty.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-24-2010, 09:06 AM | #3 |
Junior Member
Eaton Posi is a good piece and I really like the Eaton TruTrac....
08-24-2010, 12:25 PM | #4 |
+1 on the Tru-trac. For street driving I would take it over any kind of locker or clutch-type posi. It is totally noiseless and transparent. Until you need it you don't even know it is there.
Ray |
08-24-2010, 01:12 PM | #5 |
The Engine Whisperer
Auburns like to go boom. We use a Eaton clutch-type in the rear of the 68 and it's awesome on the street.
08-24-2010, 05:29 PM | #6 |
another vote for Eaton. REBUILDABLE
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
08-24-2010, 05:49 PM | #7 |
Eaton seems to be the popular choice between to two you are considering. Not too long ago i was having to decide on a posi unit as well. I ended up going with a detroit locker and i love it!
08-24-2010, 10:53 PM | #8 |
Thanks for all the input guys. I appreciate it.
08-29-2010, 11:18 AM | #9 |
you should go with yukon do your home work on them and you will not buy anything eles
08-29-2010, 04:19 PM | #10 |
I have an Auburn in my Blazer. I chose it because I have had an Auburn in my 455 rwhp Mustang that has seen tons of abuse, and I haven't had ANY issues with it. I put an Eaton in my last p/u ('87 2wd 1/2 ton), and it began to give me issues after 11 months...rebuildable or not, that's way too soon to have to deal with that .
Go Auburn!!! And War Eagle!!! |
08-31-2010, 01:57 AM | #11 |
Auburn here with allot of abuse. 450rwhp and no issues so far but only time will tell.
08-31-2010, 02:29 AM | #12 |
Eaton, When the Auburn goes bad its good for nothing but a paper weight.
09-01-2010, 04:38 AM | #13 |
I like the true-trac. Nothing to wear out and works different than a clutch/cone type. It doesnt just try to lock the wheels together, it just senses a difference in available torque from each wheel and compensates for it. In other words it doesnt care if the wheels are spinning at different speeds it just applies power to the wheel with the most traction reguardless of differential speed.
09-03-2010, 10:59 AM | #14 |
Happy to be here
What about the Powertrax by Richmond? How does that fit in the mix? LINK
09-03-2010, 12:36 PM | #15 | |
Laid Lo
Never had one in a 2wd but they don't use friction plates and all that. No need for special oils either. Just teeth on either side. You are locked up until cornering where the centrifical force allows one side to slide open and unlock one wheel. The Richmonds are supposed to be quieter than the Aussies but both are quieter than a detroit. Really not loud though, you'll hear a slight ratchting sound every now and again. Simple install too. No need to set gears etc. Took about an hour start to finish in the last D44 I did. This is the route I'm going in my 72.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
