Old 08-25-2010, 05:53 PM   #1
billsbowtie
billsbowtie's Avatar
? about painting tail light housings.
will painting the back side [part you can't see when installed] on the tail light & reverce light housings mess up my grounds or anything ? thanks for any help.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 08-25-2010, 06:13 PM   #2
gkesseru
gkesseru's Avatar
Re: ? about painting tail light housings.
Not if you use star washers and torque down hard hard enough for the washers to cut into metal. Also make sure the bed is grounded to the frame.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 08-25-2010, 07:18 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I usually powdercoat em chrome and use a dremel to clean a ground surface on the backside for the ground wire to attach to.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-25-2010, 07:53 PM   #4
JimKshortstep4x4
The original fasteners have washers with built in serations and if they are in good condition painting will not affect the grounding.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-25-2010, 10:15 PM   #5
billsbowtie
ok thanks for the info. bill
