Old 08-25-2010, 07:12 PM   #1
gregg72340
gregg72340's Avatar
4 speed driveshaft question
Does anyone know if there is a difference between a 4 speed driveshaft for 1/2 ton vs. one from a 3/4 ton? Both trucks are 8 ft bed trucks. Both trucks are leaf spring trucks.
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!!
gregg72340 is offline   Reply With Quote
Old 08-25-2010, 08:06 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 4 speed driveshaft question
I put a 3/4 ton driveshaft out of '67 into a 1/2 frame with the 1/2 rearend. I had to get what some calls a "jump" u-joint in to match the 3/4 ton driveshaft to the half ton rearend.
I like the 3/4 ton driveshaft better because it has a heavier carrier bearing.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-27-2010, 11:51 AM   #3
gregg72340
gregg72340's Avatar
Do you remember where you got the u-joint? was it something a place like Napa helped yu with or through one of the vendors?
Gregg
Old 08-27-2010, 11:57 AM   #4
LONGHAIR
"Conversion" joints should be available at your local NAPA or if you live in a big enough city to have a driveline/clutch shop, they will have them too.
You might get them at a "chain store" if you already know the part number.....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-27-2010, 05:17 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
I got the one for my truck at a Fisher's Auto Parts, also some places called Federated.
