08-26-2010, 06:54 AM | #1 |
low n' slo
Few questions on power steering
I'm trying to clean up a little under the hood since I'm replacing my motor. my 67 suburban already came with ps, but the motor is not original. did 67 already have ps in our trucks? I would like to replace my pump since I'm cleaning up the pulley and bracket. also, my steering box has crud piled on it. is there a way to tell if it works? and how can i figure out what year this stuff came out of if its not stock?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
08-26-2010, 09:07 AM | #2 |
Re: Few questions on power steering
In 67 power steering for trucks was something new. Very, very few even ordered it for trucks. Afterall $25 or $30 worth of options was considerable when most were paying house payments of $60 or $70 a month. What was installed was power assist in 67. Slightly different than the later years. Best to get a pic of what they looked like. More than likely you have the later model stuff installed. Take a few pics to determine what you have on your truck. I remember my Dad paying an extra $8 for an AM radio installed in 69. That was more than our electric bill and water bill combined.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 08-26-2010 at 09:07 AM. |
08-26-2010, 12:15 PM | #3 |
Junior Member
The '67 used a power assist power steering system and they are real easy to tell from others because of the ram that is used on the steering underneath.
It was an option so not a lot of trucks had it. It seems most people don't like the system and get rid of it and go with a newer setup.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
08-26-2010, 07:29 PM | #4 |
low n' slo
pics would help lol
the only ones i have are right when i took it off. heres the front and back of the pump.. the fluid was still in the pump, is there a way to tell if the pump any good. i can clean this one up and paint it if i can figure out if it is still good!
09-07-2010, 09:45 PM | #5 |
low n' slo
anyone?
09-07-2010, 09:53 PM | #6 |
I'd just try it to see if it work myself.
65 c10 tore apart 70 c10 305/350th |
09-07-2010, 10:02 PM | #7 |
Roadtrip!
I have a pic of a 67 setup on the WIW part of the board. An original should look like that.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-07-2010, 10:06 PM | #8 |
Old member
You maybe able to take it to a pump motor repair shop and they maybe able to give you some insight on it.
Check this link out it shows one being rebuilt on here. http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-07-2010, 10:15 PM | #9 | ||
low n' slo
i thought 67 did not come with power steering...hmm. i really dont want to to leave it up to the guys at oreilly lol. well, lets say i went and got a 71..just to say, what would be the difference in hooking it up? i have all my brackets and original pulley (to my pump), and the pulley nut. could i not just put my pulley on and brackets on and hook it up, or is there something (like hose fitting size) that would keep me from doing this?
09-07-2010, 10:36 PM | #10 |
Old member
The pump wouldn't be anything except to get the right hoses for it. The steering sector of say a 71 is completely differant. It would be a easy swap and a lot more parts in junk yards to work with also.
This is a 71.
09-07-2010, 10:01 PM | #11 |
low n' slo
is the only way to just simply bolt it up and try it? honestly, i think i would rather just buy a new one since (from what i seen at oreilly) they are only about 40 bucks. i just want to make sure the new one is the right one. its gonna get painted, and installed so i really dont have room to return it lol
09-07-2010, 10:42 PM | #12 |
low n' slo
hmm, so the steering box has to match too? maybe i can snap some pics tomorrow when i get off (if its not raining) and maybe we can figure out the year...mine is real dirty and has loads of gunk on it though, so maybe it wont help lol
09-07-2010, 11:03 PM | #13 |
Old member
The 71-72 steering sector and pumps can be bought at parts stores. The mounting of them is a little more envolved because of the frames being differant but can be done.
Any good NAPA parts store can make the hoses you need.
09-07-2010, 11:24 PM | #14 |
low n' slo
hmm, so my best bet is to take mine in, check out a few different models, and take the closest one to mine. then have the hoses made?
and if so, what year ranges are they? 67-70, 71-72, and 73+? Posted via Mobile Device
09-08-2010, 01:00 AM | #15 |
Old member
Some later model units 77-78 to are a direct bolt in as well I've been told.
I swapped my Steering Gear for one out of an '85 and it was a direct bolt up. http://67-72chevytrucks.com/vboard/s...d.php?t=419482
09-08-2010, 10:37 PM | #16 |
low n' slo
great, lol. i figure i will just take it in and try to match it up, then when i need the hoses i will take the old ones in and try to match those too lol
