Old 08-26-2010, 11:07 AM   #1
bedfordia
Rally wheel question
Hi Y'all
I have a question about these rally wheels. How do the center caps clip onto the wheel? Are my wheels missing some clips or something?
I have included a picture of the truck here too to show off. Just got here back from the body shop for a makeover. Whadda Y'all think?
bedfordia is offline   Reply With Quote
Old 08-26-2010, 11:32 AM   #2
tommyd241
tommyd241's Avatar
Re: Rally wheel question
The rally wheel center caps screw onto the wheels. You can also get some late model center caps and attach those with lug nuts that are threaded on the outside so that you can attach the lugnut covers and hold the center cap in place.
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 08-26-2010, 12:34 PM   #3
MOJO1963GMC
MOJO1963GMC's Avatar
You'd be better off getting original caps and maybe having them rechromed if needed. I bought some of those repro caps from LMC for about $50. Just chrome plated plastic. Originals are metal. The "emblems" on repros is a sticker. A sticker? Take a guess what's gonna happen to that sticker the first time it gets wet. The emblems on originals is some kind of enamel. What year range are those rallys for?
MOJO1963GMC is offline   Reply With Quote
Old 08-26-2010, 05:08 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Your truck looks great. Did it need a lot of work or just a paint job?
Old 08-26-2010, 05:31 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Shhhhh don't tell anyone but if you want baby moons for cheap $$$$ hit the big truck chrome shop and get yourself some Axle covers they lock on the corner of the lugs your going to need the ones for a 5 1/2" pattern like i said the slide over the axle nuts...you would think they would fly off bt with a little sweet talk and some lug turning a bit they go on and stay on!!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 08-27-2010, 12:36 AM   #6
Captainfab
60-66 Nut
The center caps screw on with 3) 5/16"-18 x 3/4" screws/bolts. What I used on mine are the front caps (these are for 4x4's) that no body wanted because they are open on the ends. Then I cut 4 circles from stainless steel and siliconed them in from the backside. I also painted the flange the color I am going to paint the body. Here is a pic.....
Old 08-27-2010, 09:19 PM   #7
bedfordia
Hi Y'all
thanks for the responses. Hey Captainfab I like your idea about the 4wd caps, looks like enough room to mount a Pratt & Whitney radial engine emblem in the center of the cap hmmmmmm
Old 08-28-2010, 11:39 AM   #8
gmcpkup
gmcpkup's Avatar
I used the 4X4 wheel centers also here is a picture
gmcpkup is offline   Reply With Quote
Old 08-28-2010, 11:54 AM   #9
jocko
jocko's Avatar
here's some on ebay (6 lug rally caps) - I have a similar set from another seller, and I like them. They are not the heavy metal ones - these are plastic - which I thought I would not like, until i bought them.
not sure if these come with screws.
jocko
http://cgi.ebay.com/ebaymotors/1968-...item53e3210400
Old 10-22-2010, 05:46 PM   #10
Andyboy
Andyboy's Avatar
Truck looks killer.I'll look out for it on the road.
Andyboy is offline   Reply With Quote
Old 10-22-2010, 07:47 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I remember that P&W logo when I worked there in West Palm Beach years ago. That would look cool. Make room for the wing tips.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-23-2010, 08:37 AM   #12
lakeroadster
jocko
I bought a set of those caps off Ebay a couple years back and they did indeed come with the attaching screws.
They seem to be good quality, even though they are plastic.
I was toying with putting them on my aluminum slots, but then decided against it.
lakeroadster is offline   Reply With Quote
Old 10-24-2010, 11:14 AM   #13
protrash64
Resistance is Futile
protrash64's Avatar
The slots look like it should have been factory with the caps sitting on them
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-23-2010, 02:22 PM   #14
chevy_mike
Never Ending Projects
chevy_mike's Avatar
When I was at the Pomona Auto swap last weekend, I ran across a guy who is making clips that work for truck rally's. They were stainless steel clips that bolt to the holes for the factory caps. Once the clips were mounted, you can use any of the car rally caps and I would assume baby moon caps. It was really a slick idea and the wheels looked great with derby caps, painted wheels and trim rings. He was asking $60 for the full set and said they worked for both 5 and 6 lug truck rally's. It was a cool idea.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-24-2010, 10:53 AM   #15
astrochimp
You can also use the hub cap bolt holes to remove a wheel that it stuck on.
You need 3 about 1' long, thread them in till they hit the brake drum, them tighten evenly to pop off the wheel.
There are 2 sets of holes, that on my wheels were a different size.
astrochimp is offline   Reply With Quote
Old 10-24-2010, 11:07 AM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I just got a set of those wheels as well .... thinking about machining out some rings to 'cover' the slots in the wheels. Weld them in or bolt in from the rear ...
Then, I'll move onto a hub cap. Good ideas here, like the axle cover one !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-24-2010, 11:25 AM   #17
Chevy Fleetside
Chevy Fleetside's Avatar
I have six of those wheels. I think I have one center cap. I don't even remember where I got them from but I think they were free.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-24-2010, 11:44 AM   #18
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
.... now you tell me
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-25-2010, 08:47 PM   #19
creep
Registered Loser
creep's Avatar
I used the newer style caps with the black lug covers that thread onto the nut. I just painted the centers to go with my GMC.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
