08-29-2010, 07:09 PM | #1 |
Please help, brakes suck on 72 c/10
I have a 72 c/10 that i am about ready to go crazy with. I just got this truck and the brakes have never stopped good since i,v had it. It does not have soft pedal and it doesn't go way down to the floor, feels like it should stop on a dime. But, this thing does not like to stop, it's got power brake booster that is working, i can feel it helping the pedal. I have to stand on these brakes to stop. I have switched master cylinders, no help, I took some of the proportioning valve apart part way, ( took off big nut and spring off end) looked good. I even capped off the port that feeds the rear brakes to see if the front discs were working some and they seem real week. the only other info I can think would be importent is the truck does stop in a straight line no pulling side to side, Right now i,m leaning to a bad p valve, but any help i would love
08-29-2010, 09:51 PM | #2 |
Grandpa in the rustmobile...
Re: Please help, brakes suck on 72 c/10
interested in this too...my brakes hold and stop crappy, let us know if you put a new vavle on and where ya get it and how much, and if it helps!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-29-2010, 10:19 PM | #3 |
So i take it that you have disk front. When as the last time the brakes were bleed? Have you had to top of the fluid latelty? How long have you owned the truck? Is the booster really working? Were is the booster plumbed to (manifold right)? Have you had the rears apart and adjusted them properly? When you switched the master cylinder did you make sure the pushrod was the right lenght? Did you bleed the MC before you put it togther? Just need more infor to diagnose properly.
08-29-2010, 10:32 PM | #4 |
hmmm
does anyone know the length of power booster rod? I wonder if i could have forgotten to swap it out, so no matter HOW much i adj. it does no good?..
08-30-2010, 01:16 AM | #5 | |
13lazers' blazers
maybe you have fluid or grease on your rotor or drums. that will keep you from stopping for sure.
1970 2wd blazer 1972 1ton blazer 4x4 in progress 1966 mustang coupe (modified) 1985 c20 suburban tow rig 1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat almost all exempt from california smog laws intentionally. |
08-30-2010, 07:38 AM | #6 |
have you replaced your pads and shoes?
08-30-2010, 09:39 PM | #7 |
me? yes. but i think your talking to the guy i hijacked the thread from..lol
08-30-2010, 10:52 PM | #8 |
today i took the proportioning valve off of my 72 blazer that I know works and put it on the truck. Brakes still hard. took all rubber brake hoses of and they are not swollen shut, pass air fine. decided to take booser apart. after beating on it for a bit I got it to seperate and found the back rubber diaphram had a 2 inch tear in it, so I hope this will fix it. i'll keep you guys posted, he's a pic of the truck a couple weeks ago after i painted it, I was still cut and bufing it in the pics
08-31-2010, 10:16 AM | #9 |
Glazed over pads/shoes and or rotor?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-31-2010, 11:05 PM | #10 |
today I got a new booster at carquest, $109.00 and it fixed the problem, so I am going to start enjoying it now. thank you guys for all the help, this is the best board.
