inner tie rod compatibility?
what i have: 70 c20 with 82 c20 spindles.
ok here is my dilemma. i bought outer tie rod ends for the 82 spindles. the threads are larger on the new tie rod. i was wondering if inner 82 tie rods will fit into the ?drag link? (the rod that is in the center) so i can use 82 tie rod sleeves. thanks in advance. sean |
Re: inner tie rod compatibility?
bump. if its a no go im just going to build my own tie rod sleeves
67-72 parts collector,…
![]() Join Date: Nov 2002
Check the thread direction on the two tie rods.
One needs to be left hand and one needs to be right hand. I believe what you have will be the same "thread direction". www.performanceonline.com sells a tie rod adapter that will connect the '82 outer to you old stuff,... but you have to use '67-'70 "outer" tie rods (as inners) with your '82 outer tie rods. Your 82 outer should be 11/16" diameter and your '70 stuff will be 5/8". Hope this helps.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-30-2010 at 09:56 PM. |
#4 | |
![]() Join Date: Oct 2001
When they went to disc brakes starting in '71 they made the tie rods bigger and reversed the thread direction. Tom
'69 swb stepside in progress. '59 Corvette lifetime project Last edited by basketcase; 08-30-2010 at 11:51 PM. |
#5 | |
thanks alot guys. i searched everywhere on ccp and performanceonline with no luck on finding the adapters. usually im not so useless i need a link to the exact part i need but this time i do. haha
#6 | |
![]() Join Date: Feb 2001
Heres a bump...Hang in there laid_out_70 and I am sure someone can offer you some help... ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Here you go:
http://www.performanceonline.com/196...-SLEEVES-PAIR/ Hit the "drop down" arrow. It's part number HPAS63-70 $49.99/pair
#8 | |
Ray |
Thanks guys, just used all this info to order this part for my truck. I tried mixing and matching parts to get my truck on the road. I have a 1966 C10, I used '82 Spindles and brakes. Been driving it for about 8 months. But the steering is always giving me problems. Hope this works!!
1966 C10, SB305, bagged. 1955 VW Buggy, 2.0L 1978 Honda CB550 http://67-72chevytrucks.com/vboard/s...9&goto=newpost |
bumping this instead of making a new thread. i also ordered a proportional valve. ive been told mixed things about the master cylinder. will i need to get a different one? its a 70 c20 with 82 discs up front
Get a 71-72 master cylinder and proportioning valve,... Or do like I did and buy a m/c prop valve combo from performance online.
