08-31-2010, 12:15 PM | #1 |
Gas Tanks
I have an '84 chevy short bed with factory dual tanks. Are these interchangeable from driver to passenger side?
My drivers side has a leak, so I want to move the passenger side tank over and get rid of the bad one. I will then fill the passenger side door. |
08-31-2010, 02:58 PM | #2 |
Re: Gas Tanks
Tanks are interchangeable from side to side but sending units are not so you have to switch that also
08-31-2010, 04:07 PM | #3 |
Re: Gas Tanks
Thanks for the info.
08-31-2010, 05:09 PM | #4 | |
Still plays with trucks
Re: Gas Tanks
What about leaving it alone and just running on the passenger side tank for a while? You may find that a single 16-gallon tank is no fun at all when you have to stop at the gas station twice as often.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
08-31-2010, 05:34 PM | #5 | |
Re: Gas Tanks
08-31-2010, 05:46 PM | #6 | |
Re: Gas Tanks
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
08-31-2010, 05:53 PM | #7 |
Re: Gas Tanks
Now imagine if you got 7 mpg like I do. I'm just glad I don't have to drive that far.
08-31-2010, 05:18 PM | #8 |
Re: Gas Tanks
True.... I can maybe find a used tank on Craigslist also. It would keep me from having to fill the other gas door too.
08-31-2010, 06:54 PM | #9 |
Re: Gas Tanks
If you are going to go to one tank, why not try and put a Blazer tank in the rear? I know that interferes with the spare, but you can get a single tank with a larger capacity that way. I was thinking about doing something like that with the filler neck coming out behind the license plate.
08-31-2010, 07:18 PM | #10 | |
Re: Gas Tanks
Standard capacity is 31 gallons so it is pretty much the same as dual tanks on a short bed.
08-31-2010, 09:41 PM | #11 |
Re: Gas Tanks
Good point about the filler neck, I hadn't thought that far into yet. I suppose it could be customized to work with a fuel door installed in the right location on the bedside, and then fill in the old ones. However, with that much work involved, it would probably be easier to repair the existing tank.
08-31-2010, 11:40 PM | #12 |
Re: Gas Tanks
i just brought a new fuel tank for 85 swb.
Dorman 16 gal including lock nut and o-ring from parts geek $110.98 They seemed to have the best price with low cost shipping. Last edited by Scottsdale Doc; 08-31-2010 at 11:41 PM. |
09-01-2010, 09:10 AM | #13 |
Re: Gas Tanks
I have a drivers side great shape w/sending unit and whatever else you need on an 83 1/2 ton chassis I can't get rid of. Before it goes to scrap heaven I need to cut the tank in half or they won't take it. You can have it for the cost of shipping, however iIhave never tried to ship a "used" gas tank across the country so that might be a pain. PM if it's worth it to you.
09-01-2010, 11:07 AM | #14 |
Re: Gas Tanks
PM Sent. Thanks.
It sounds like either way, a new (or used) gas tank would be the way to go. |
09-01-2010, 11:58 AM | #15 |
Re: Gas Tanks
I bought a used gas tank from a friend that was parting out a truck for $20 with the straps and sending unit. It was a lot cheaper than a new tank, you just have to make sure it's good and clean before you install it.
