need help with exhaust setup for in-line 6
try to find info on exhaust setup for inline 6 (230) . I need to run exhaust pipe from header back, every shop I call wants to charge between 150-170, I want to do it myself pretty good at welding, does anyone have a picture or info so i can see angle of pipe I need to run. Thanks
Keep knockin' on the Devils door, eventually someone's gonna answer. ![]() 1965 c10 Longbed Fleetside 1972 Chevelle (wife's car) 2002 Suburban (wife's car) |
HOW long until spring??
![]() Join Date: Mar 2009
Re: need help with exhaust setup for in-line 6
I used 2"EMT conduit and a hydraulic bender from work.--
Kicked it outside the frame and turned it out in front of the tire. http://67-72chevytrucks.com/vboard/s...d.php?t=365170 Check it out Page 6 -Bubbas recycling project in 60-66 project and builds
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
Thanks thats just what i needed, your the man.
Hollister, CA.
![]() Join Date: Sep 2006
FYI, I have a decent exhaust on my truck currently (292 though) .... I plan on ripping it out, and running something different.
Flows into a flowmaster, then splits in front of the rear wheels.....looks recent (few years I guess) If you can use it, your welcome to it !! Here's a pic: - - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 09-01-2010 at 09:29 PM. |
[ATTACH]
Chief this how my engine looks, would that work?
Just a friendly suggestion, which I know you didn't ask for......
Unless you have another connection on the valve cover which doesn't show in that pic, you should run a vented cap with that PCV setup. Otherwise, there is no way for fresh air to get into the crankcase. Ray |
I just recycled the first foot with the flange and welded on new from there. 2" EMT is a little bigger diameter but not much.
I have made new flanges before by heating with a torch and working it over a ball hitch. Bubba
Six in a row makes it go...
I took a Y-pipe for a Nova that was laying around and cut the ends off. Then I welded new ends on that were oriented correctly. This was a 2 into 1 exhaust.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
I might have to try some of these ideas,that's the only thing holding me from driving my truck. I can't seem to find a flange to hookup to manifold,getting fustrasted.
"Where were you in '62?"
![]() Join Date: Jul 2004
You need to look here!
http://67-72chevytrucks.com/vboard/s....php?p=2967357
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
