09-02-2010, 08:40 PM | #1 |
2 Hole Dash Panel Anyone?
Does anyone know where I can find a steel or aluminum 2 hole dash panel? I'm trying to run something like these gauges on my 72 and I keep hitting deadends. I can find the six hole variety all day long just no 2 hole.
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast" 68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger" |
09-02-2010, 08:48 PM | #2 |
Insert Title Here
Re: 2 Hole Dash Panel Anyone?
I think trucksusa.net has them
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
09-02-2010, 08:57 PM | #3 |
That got me from 6 down to 3. Getting warmer. I could always do the above setup with a 3 3/8" Tach which wouldn't be too bad.
09-02-2010, 09:11 PM | #4 |
I was doing the panels and I saw your post on my thread. I could do the panel but right now all my machines are tied up on a huge 3 year contract and it will be months before I free a machine up. If you are not in a hurry, I could do the job in a 3-5 months.
09-02-2010, 09:40 PM | #5 |
Cops, ha, catch me if you can!
A while ago, I saw a post on here where someone used a Glove Box Door, modified it and used it for their instrument panel. If you have some fab skills it dose not look all that hard to do.
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies |
09-02-2010, 10:09 PM | #6 |
Old member
What he said, use a glove box door it's the same size just drill holes and cut out for the steering column.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-03-2010, 12:39 PM | #7 |
I have seen your work and it is top notch
09-03-2010, 04:57 AM | #8 |
What I done was cut out an 18g steel peice to fit neatly into the centre of the panel then cut the holes where I wanted and got rid of any plastic that got in the way,welded small studs in the back to attach it to the plastic, sprayed the outer peice with silver paint and the steel panel with a wrinkle finish paint
09-03-2010, 01:53 PM | #9 | |
09-05-2010, 08:45 AM | #10 | |
Thanks S.C. Posted via Mobile Device
...try'n to be a little! This is a great site. http://67-72chevytrucks.com/vboard/s...d.php?t=157669 http://www.67-72chevytrucks.com/vboa...d.php?t=375640 |
09-03-2010, 06:42 AM | #11 |
Collector of Projects
When I hd my 71 stepside, FuelCellGuy had an aluminum panel that was blank with no holes... Never did get to install it .. it went with the truck when I sold it ....
09-03-2010, 11:49 AM | #12 |
PROJECT 7DEUCE
I know teeitup have a ton of glove box doors for sale right now on the classified..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
