Most likely reason fan isn't working?
I'm about to dive into my AC/Heater system that isn't working.
The fan doesn't work and that is my first task. Is there a more common reason why? I've checked the fuse and my wiring harness is intact. Thanks
1972 GMC Sierra LWB (Aquafresh) 1962 Cadillac Convertible 1962 Cadillac Sedan project |
Re: Most likely reason fan isn't working?
sometimes the housing is filled with 40 years of crap and vermin and the fan wont turn
Check to see if your getting power at a few points with a test light. At the fan it's self (with the switch on) at the switch (it's the brown wire). If your getting power at the fan then your fan is more than likely bad. If your getting power at the switch, check the relay.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Redefining LowBudget
run a wire from the batery to the fan there pretty close that will proably blow your truck full of crap ;eaves and dust....but at least you'll know the fan is good.....next head down to auto zone ( where I got mine) and buy the heater/A/C fan relay its about $15 then pull your glove box and on the side of the heater box up agains the wall you'll find it....repace it!!!! its to much of a PIA to get to and not..... I bet a piece of pizza that its your issue....next would be the switch
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
HUA problem on my end ... you already said the fuse was good. Doh!
Well good thing my glovebox is a mess and comes out very easily!
Thanks for the tips guys, I appreciate it.
sharp as a marble
![]() Join Date: Jan 2007
nobody mention checking the ground side, of this system. Ask me why I would say that! Do you have power at the blower motor? do you have a ground at the motor? Confirm 12v+ at the blower switch, and move to the relay from there. Don't forget the ground side
lovin' the lowcountry
I agree, this is what caused mine to stop working.
Chris 29461 72 SWB stepside ![]() 71 SWB stepside ![]() DRIVE IT LIKE YOU STOLE IT! |
^^^ why would you say that???
sharp as a marble
