09-04-2010, 10:05 AM | #1 |
A different clutch fan option
Some of you myself included wanted to keep things simple and stay with a clutch fan for cooling. My situation was very unique as I was trying to keep my engine as high as I can for additional differential clearance while still using the factory clutch fan and my factory shroud. If you leaned on the shroud even very slightly or romped on the gas pedal the fan would hit the shroud. Every now and then I would notice the temp gauge getting very hot and found the fan stopped on occasion.
I had read somewhere that a F**d explorer 95-01 4.0 fan was 1 inch smaller in diameter and the shaft was about 1/2 inch shorter giving more radiator clearance if needed. I didn't need the extra space so I drilled the F**d fans smaller holes so it would fit my 5.3s clutch assembly. The new fan has a more aggressive blade pitch and no longer hits my shroud. I believe I have solved my getting hot issue and thought I would share. Sorry I took no pictures!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
09-04-2010, 10:15 AM | #2 |
Gone Fishing
Re: A different clutch fan option
Thanks for the info. I just tried a fan and clutch off a 96-98 votec 350 truck engine and the fan is too big for the factory truck small block fan shroud
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
09-04-2010, 12:22 PM | #3 |
Good to know. Thanks.
09-08-2010, 10:48 PM | #4 |
GM ONLY BABY!!!
My LS clutch fan works with my 72 shroud, I just slotted it a little in order to raise the shroud up about 1/4" in order to gain even more clearance, Clarence. My 6.0 hasnt been above 190*.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by chevydog66; 09-08-2010 at 10:49 PM. |
09-26-2010, 09:00 AM | #5 | |
Just giving an inexpensive option (compared to electric fans) in case someone else experiences fan interferance like I did.
