Old 09-05-2010, 08:59 PM   #1
zimmstoy
Harmonic Balancer Failure
Hey everyone,
I ran the 87 Camper Special 454 truck today had it cruisin pretty fast. Came home and parked it, shut her down and heard a horrible noise. Sounded like the flywheel broke in half. After further inspection i found that the weighted part of the harmonic balancer (the piece with the timing mark) actually separated from the balancer. It is rattling around pretty bad. Needless to say I need to replace it. Has anyone had this happen before? Is it as simple as a separated balancer from the weight or is there something deeper I should be looking into?
I was running the truck today around 85mph with the turbo 400 in there I suspect I was going around 4500-5000 rpm (is this a bit much for a stock balancer? Anything I need to look for in a replacement balancer?
Kind Regards,
Scott
zimmstoy is offline   Reply With Quote
Old 09-05-2010, 09:48 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Harmonic Balancer Failure
the harmonic balancer is basically glued (vulcanized IIRC) to the center piece with rubber
over time they will wear out and separate.
just replace the balancer, and good luck
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 09-05-2010, 10:07 PM   #3
zimmstoy
Thanks I will get on that. Should I just replace with a stock replacement or is there any reason to upgrade or put a performance upgrade on it?
Kind Regards,
Scott
Old 09-05-2010, 11:05 PM   #4
dammitmitchell
the pollock
i wouldnt unless your trucks suped up a bit.
im running a stock balancer on mine still. but measure the size across because there are multiple options for balancer size
Army vet 02-08
Old 09-05-2010, 11:07 PM   #5
spudz
spudz's Avatar
spinning that big block at a constant 4500-5k.....you will have alot more then a balancer failure in your future....
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 09-06-2010, 01:01 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ive had several of these go out on older vehicles over theyears... one happened while pulling the wheel off to do a timing chain.. didnt notice it had broken some until i fired up the motor ....i wouldnt go hi performance on one of these for a regular motor like the other poster said
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
