Old 09-05-2010, 11:03 PM   #1
Schralper
Schralper's Avatar
E-Brake intermediate cable, help?
Ok so I have not had ANY luck finding the right length cable for my ride,
68 Longbed, SBC/TH400/12b.
The cable that was on was fraying, right where it goes through guide on tailshaft housing. It's 119".
Neither BBC/TH400 or SBC/TH350 cables fit.
BTW- Also need the cable guide on RH side, for solid rod. PM me if ya got one.
Took the truck for a spin w/o cable & forgot about it and it disappeared
Schralper is offline   Reply With Quote
Old 09-06-2010, 07:01 AM   #2
rsavage
rsavage's Avatar
Re: E-Brake intermediate cable, help?
You could check with inlinetube. They make them up.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-06-2010, 11:05 PM   #3
68K30
NAPA also lists them by length in their brake catalog, run a piece of heavy cord around all the anchors and mark the ends and measure.
68K30 is offline   Reply With Quote
Old 09-07-2010, 11:11 AM   #4
Schralper
Schralper's Avatar
Yeah, looks like Inline might be my best bet. LMC wasn't.
Nuthin against NAPA but my local one has pissed me off to many times.
Anybody got a line on the equalizer that fits on solid rod??
Old 09-07-2010, 11:38 AM   #5
vectorit
What?
vectorit's Avatar
I got all those pig tails, and the equalizer rod from LMC. They have it as a kit.
The cable shouldn't be a big deal, just search on your wheel base.
You could have some differing year parts in the mix that could be throwing everything off?
Or, if you are missing a pig tail it will seem as though your cable is too long.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-07-2010, 06:18 PM   #6
Schralper
Schralper's Avatar
yeah vectorit
I saw LMC has got the whole kit but I only need the RH side equalizer.
Was kinda hoping someone here had one cheap.
LMC doesn't have the cable nor any places I checked. I gotta call to double check there lengths w/ Inline tube.
Cuz the ones I've gotten have been to short.
It was all there hangers & all & working, til I thought I got the right cable & it wasn't.
I'm not gonna put the frayed one back in.
Old 01-10-2011, 07:24 PM   #7
es67chevy
es67chevy's Avatar
You ever find the right length? I'm running into the same thing with my 67. Thought I bought the right one from Classic Parts, but its too short.
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 01-11-2011, 12:58 AM   #8
chewychevy67
I ordered a few for my 67 swb from all my parts books and none were correct or even close for that matter. finally phoned inline tube and had one made from my own measurements and now my e-brake works correctly. very inexpensive compared to all the other crap i bought before calling inline.
chewychevy67 is offline   Reply With Quote
Old 01-11-2011, 11:43 PM   #9
es67chevy
es67chevy's Avatar
Cool! I just ordered the one they say is for a 67 from them so hope it is right for my truck. If its not, maybe I can get them to exchange it.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 01-29-2011, 10:44 PM   #10
es67chevy
es67chevy's Avatar
Well, got one from inline tube. Does anyone have a pic of what it should look like installed? Ours never had a good one so I'm not sure if mine is still too short or if this looks normal. Here is a pic of it from engine compartment. I need to get underneath and take some shots too, but hoping I can get some pics of successful installations.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 01-30-2011, 01:44 AM   #11
vectorit
What?
vectorit's Avatar
Scroll up, and study the diagram.
From your photo it looks like the cable is missing the frame connectors that are under the driver/passenger seat, these are just heavy steel wire hooks that add tension and straighten the cable along the frame towards the rear of the truck.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 01-30-2011, 02:04 PM   #12
es67chevy
es67chevy's Avatar
Yeah, looked at the diagram. Thanks for providing it. I have the frame connectors. The line just seems too tight to connect them. I'll try tonight and take some pics of my results. Also seems I need to get some grommets for the places where the line passes through the crossmember.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 01-30-2011, 02:06 PM   #13
67chevy1series
67chevy1series's Avatar
heres a link
67chevy1series is offline   Reply With Quote
Old 01-30-2011, 11:38 PM   #14
es67chevy
es67chevy's Avatar
OK, here's the problem I ran into. As you will see in the photos, I can only get one side hooked with the...well, I'm not sure what they are called, but I think the pics are self explanatory. Oh, and to have it all hooked up like I do, the emergency brake is currently engaged. Both back wheels are not turnable. Argh! It seems I need about 3-4" more length in the intermediate cable to give me enough room to use the other hook and to disengage the brakes.
Passenger side hooked but driver's side unable to reach:
Driver's side unhooked:
This shows the distance I still need to connect the driver's side:
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 01-29-2011, 11:07 PM   #15
steelscout
Words under my name
steelscout's Avatar
subscribed
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 01-30-2011, 01:53 AM   #16
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Subscribed
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-30-2011, 01:56 AM   #17
67chevy1series
i made a thread with pics......
Old 01-30-2011, 02:01 PM   #18
es67chevy
es67chevy's Avatar
Is it in your build thread? If so, what page? Thanks.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 07-27-2012, 01:38 PM   #19
es67chevy
es67chevy's Avatar
I had a custom one made by Inline Tube. Just used the one they gave me and told them how many more inches I needed. i think I added about 5". If you have your old cable, you can have them make you one to the same length. If not, you may have to order the stock one and then figure out what length you need.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 07-27-2012, 03:25 PM   #20
leddzepp
Moderator
leddzepp's Avatar
I bought ALL of my e-brake cables from Carquest. They had all the parts on the shelf....you just need to find a good counter guy that knows what he is doing (that is the hardest part)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
