Old 09-06-2010, 01:59 PM   #1
Security guy
Security guy's Avatar
Turbo 350 tranny question
I got a question for the transmission guys. I got a 383 stroker backed by a 'built' 350 turbo tranny. I bought this 'as is' so I dont know what has been done to it. The problem I got is that it seems to shift fine, but its squirting tranny fluid out of the kickdown cable onto the intake manifold. It does it every time it shifts. I have only been able to take it up the road for a 1/4 mile or so. Im afriad of something catching on fire until I can find out what is causing it. I hope I don't have to pull the tranny. I can here bubbling like after I shut it off out of the kickdown cable. It does have a tranny cooler and the fluid level seems to be right where it should. Any thoughts? Thanks.
Security guy is offline   Reply With Quote
Old 09-06-2010, 02:46 PM   #2
cdowns
cdowns's Avatar
Re: Turbo 350 tranny question
have you checked the vent tube// passenger side above where the cooling lines go?
Old 09-06-2010, 02:52 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Tube? TH400 has a tube, dont see one on a 350...
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 09-06-2010, 03:45 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
There's a tube on th350s if you burn one up like I did and overfill the thing on accident then fluid comes out the top of the tranny.. Should be a (mines metal)tube coming up out of the right hand side of the tranny almost on top check to make sure it is clear of mud or possibly dirt dobber material if the truck was sitting for a while.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-06-2010, 04:07 PM   #5
71meangreenc10
I have a 350 on the ground and one in my GMC and the only tubes on the passenger side is the fill tube and the vaccum line for the modulator...Would love to see a reference pic.
I will look into some more troubleshooting stuff i have to see what could be causing the over pressure situation.
Smitty
71 C30 Wrecker
Old 09-06-2010, 04:23 PM   #6
tonypaul
tonypaul's Avatar
Right where the kickdown cable bolts into the trans- take out the 7/16 bolt pull out whole assembly (beware of trans fluid coming out) replace the o-ring on the plactic shaft... That should fix it!
tonypaul is offline   Reply With Quote
Old 09-06-2010, 04:36 PM   #7
71meangreenc10
Found the vent....Its on the driver side, see if a insect has plugged it up. If not you have bigger problems if fluid is getting that far up on the manifold. You can push air through the dipstick tube to see if the vent is clogged, dont push too much through or you will catch it all back (fluid) when you remove the air. You should hear air coming out the vent if its ok.
Smitty
71 C30 Wrecker
Old 09-06-2010, 08:13 PM   #8
Security guy
Thanks for the tips guys. I'll have to get under this thing and check it out.
