Old 09-06-2010, 10:34 PM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
I've searched and can't find the answer. Brake light in dash '68
The BRAKE light is on in my dash in my '68 truck. I've got a gauge cluster.
What causes this because the hand brake doesn't have a switch?
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 09-06-2010, 10:35 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: I've searched and can't find the answer. Brake light in dash '68
low fuild in the master cyl.?
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-06-2010, 10:56 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
It indicates that the valve in the Proportioning Valve Assembly has actuated. If you look at the valve assembly you will see the wire connected to it. Usually means that one of your brake systems has failed. (front or rear)
LockDoc
Leon
Old 09-07-2010, 07:15 AM   #4
cdowns
cdowns's Avatar
yes it's an indication the brake bias is bad at the distribution block// check your wheel cylinders for leakage
Old 09-07-2010, 02:53 PM   #5
tkeduk8r
tkeduk8r's Avatar
if you want to have the brake light come on when you have the ebrake come on you can pirate the set up off of an 81-87 p/u and modifiy it to work with either the hand brake (67-68) or the 69-72 foot pedal e-brake....
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 09-07-2010, 09:27 PM   #6
whitesswj
Embrace the Redneck
whitesswj's Avatar
Our trucks don't sense the level unless it's drained empty.
'01 Camaro
Old 09-07-2010, 09:26 PM   #7
whitesswj
Embrace the Redneck
whitesswj's Avatar
Yes, I had a brake line fail but it was on before the failure. How do I reset this switch.
'01 Camaro
Old 09-07-2010, 10:03 PM   #8
LockDoc
LockDoc's Avatar
I think the '68 valve resets itself when you use it if everything is up to snuff. Some of the valves have a manual reset on the front of the valve body. There will be a small rubber cover over it if it has the manual.
LockDoc
Leon
Old 09-08-2010, 12:56 AM   #9
whitesswj
Embrace the Redneck
whitesswj's Avatar
LockDoc
I'm gonna go look right now
'01 Camaro
Old 09-08-2010, 01:14 AM   #10
whitesswj
Embrace the Redneck
whitesswj's Avatar
Mine looks exactly like this one. Minus the Power setup: There is no reset...
'01 Camaro
Old 09-08-2010, 11:00 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
If the brown wire that connects to the valve is grounded, it will turn on the light. Pull the wire off and see if the light goes out. If it stays on the brown wire is grounded some where, and if it goes out the problem is in the valve.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-15-2010, 12:37 AM   #12
whitesswj
Embrace the Redneck
whitesswj's Avatar
I pulled the wire and the light goes off and stays off.
Yesterday it flickerd before I pulled it. How do i reset that thing? It's driving me nuts...
'01 Camaro
Old 09-15-2010, 07:41 AM   #13
mrein3
mrein3's Avatar
In the part you took the wire off, the bias is wrong. Think of it as a check ball in there. When you lose either the front or the back, the check ball in there slides that way, grounds the wire to trigger the light, and blocks the leakage to that side (front or back) of the system and quite possibly saves your life. Before this safety feature and a split master was put into vehicles you didn't know you had a brake system leak until you hit something.
To reset it you need to:
1. Fix all the leaks.
2. Bleed the system at all four corners.
Check all brake line and brake hose joints and all four wheel cylinders. Any moisture = leak. Once that is all up to snuff, I would at a minimum bleed at each corner until you get clean, fresh fluid out of each bleeder. If the light didn't go out yet it is stuck from having crummy, old fluid in there. You need to gently bang on the side of it and keep bleeding fluid until you can coax it back into place.
Do make sure your wire isn't cracked and grounding some place else.
Don't simply leave it disconnected. I'm guessing that if you disconnected it and it makes the light go out that the wire is fine. You just need to recenter the check ball in there.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-15-2010, 08:39 AM   #14
LockDoc
LockDoc's Avatar
Or replace it...
LockDoc
Leon
Old 09-15-2010, 10:33 AM   #15
68K30
Your unit looks like it's just a differential pressure switch, it senses pressure difference between the front and rear brake circuits. AMC had a similar switch on the older cars and once the switch was tripped by low pressure in one circuit the switch would remain tripped until it was manually reset even if the pressure was equal in both circuits. To reset the AMC's you had to unscrew the terminal the wire plugs onto, the terminal may be white plastic[nylon] and has a hex head [7/16" or 1/2"] and press on the brake pedal to center the piston in the block then re-install the terminal and reconnect the wire.
Hope this helps
68K30 is offline   Reply With Quote
