fan shroud/ fan width?
ok guys i need a little advice/ help! i recived my fan shroud via ups and its time to install it.im running the old clutch fan which measures 19"that i want to get rid of, and i have a flex fan im thinking about using my ?'s are the opening for the shroud measures 19 1/2" and the flex fan measures 17" is that gonna be alright to run and pull enough air or does the fan need to be bigger? im worried if i go bigger is there gonna be any chance the fan hitting shroud if motor flexs/moves ? and how far does the fan need to be in the shroud for proper performance? i've never addressed fan shroud's before so im in the dark any help is appreciated!
Re: fan shroud/ fan width?
the blade should extend into the shroud half the width of the blade and have a maximum of no more than one inch clearance between the outer blade and shroud to function properly and my only experience with flex fans was losing a blade and completely trashing my radiator,shroud and hood so i prefer clutch fans or electric hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
Look at companies like YearOne, and get the biggest reproduction fan with the most blades you can get. I have a 7-blade fan for a big block with A/C... I think it might be Chevelle.
It should give the measurements. If I'm remembering it right, it's a little over 18 inches across. Do NOT get their cheaper repro fan... it's got a sticker on it that says "Do not exceed 4,000 rpm." WTF?! I think it's source from Flexalite. It's steel, but they say not to take it above 4 grand... 4 grand isn't that high. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
