Old 02-25-2003, 10:01 AM   #1
Bilgewiper
you guys are right!!....new sway bar is great!
Bought my 71 C-10 a few months ago and right after bought a bar off a 80 something camper special. Purposely didn't install it right away so I could get used to the original little bar to see if I could tell the difference after installing new bar...........Oh wow! Oh yea! Big improvment. Best $15 I have spent yet at a "You pull it yard"
Thanks for motivating me to get one
Ethan
Ethan
'71 C-10 LWB Cheyenne 85K miles.
"Time spent Boating is NOT deducted from ones lifespan".
Bilgewiper is offline   Reply With Quote
Old 02-25-2003, 12:18 PM   #2
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Ya i have one too, just waiting to be installed, i got all the parts from "Pick your Part" but the part I couldnt get, were the brackets for the front of the frame, they were all riveted on!!! I ws torture, so many of them, but i couldnt get any off the damn trucks!
Oh well im gonna figure out a way somehow....maybe haha
But I really wanna get it on there, after all these testimonies of how great the sway bars are, especially since I am used to never having one at all, I hope its a big improvement.
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 02-25-2003, 12:29 PM   #3
Bilgewiper
I took a cordless/battery powered drill in to the yard (they said it was ok) It wasnt too bad drilling them out, actually I only got 1 out and gave up because I had forgoten to take protective goggles and the stuff was falling in my eyes so I did that 1 with my eyes closed thinking I would just come back later if I needed them.....I didn't
Ethan
Old 02-25-2003, 12:31 PM   #4
MandarinSixSeven
Seasonal Poster
you didnt need them? so what did you do? just bolt the sway bar bushings to the frame? I was thinking of trying that, but does it work?
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 02-25-2003, 01:20 PM   #5
Bilgewiper
my truck came with a small bar from the factory.....I just upgraded to the larger one. I used the smaller bars brackets which were the same as the larger one's, I just didn't know it at the time while I was at the wrecking yard so I tried to get those too but keeping my eyesight took precedence.
Ethan
Old 02-26-2003, 02:53 PM   #6
Mike C
Mike C's Avatar
Early Classics sells a "lowered" sway bar mount that is just the ticket if you plan on lowering your truck 4" or so in front. Get the junkyard bar and the EC brackets and you should be good to go.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2003, 03:13 PM   #7
Oborny71
Oborny71's Avatar
so which years use the larger sway bar?
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 02-26-2003, 04:04 PM   #8
Bilgewiper
I am No expert but I think thru 1987 3/4 camper specials and 1 tons. I just walked around the wrecking yard looking for one's thicker than mine.
Ethan
Old 02-26-2003, 04:11 PM   #9
GMC Jim
GMC Jim's Avatar
Bilgewiper.... sure would apprecaite knowing the thickness (diameter) of the heavy duty sway bar you just installed... will compare with mine.. as I suspect my swaybar is light duty... Thanks
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 02-26-2003, 06:11 PM   #10
lukecp
Formerly yellow72custom
lukecp's Avatar
So any '67 up 2wd sway bar will bolt up to my '72 C10? If so i may go junkyarding myself. Would it be a bit easier to knock out the rivets with a chisel and big hammer ?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-26-2003, 06:58 PM   #11
Bilgewiper
using a tape measure and not a caliper tool......It looks like I went from a 1" to a 1-1/4"...........Seat of the pants felt like I went from a Caprice to a Z/28
Ethan
Old 02-27-2003, 05:25 AM   #12
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
1-1/16th th 1-1/8th
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 02-27-2003, 06:03 AM   #13
GMC Jim
GMC Jim's Avatar
I measured my sway bar with a caliper..... it is 1 1/6... consider that size a heavy duty one ?????
