Old 09-13-2010, 09:56 AM   #1
gcgordon
Talking 1pc Driveshaft swap 71 SWB Fleet TH350
Hello to all and i am glad to be a member of thge forum since I have started my 71 SWB project truck. I am try to find out if there is a direct replacement driveshaft from a late model PU that I can swap in. Please help! Thanks.
gcgordon is offline   Reply With Quote
Old 09-13-2010, 01:55 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 1pc Driveshaft swap 71 SWB Fleet TH350
I'm sure if you value your time at all it would be cheaper just to have a driveline sop make ou a shaft with your trans yoke and measurements from YOUR truck.
I think theirs about 6 loations you can mount your engine in these trucks and after 40 years who knows what engine stands are being used, if they have been swapped from left to right or if someody started drilling holes.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-13-2010, 06:07 PM   #3
LEEVON
Moderator
LEEVON's Avatar
I think ***disclaimer*** because it is me just thinking...but search around this site a bit because I seem to recall that 88-98 swb has a similar length like 56 3/4" or 58 3/4" something like that. Anyways those are fairly easy to find and cheap.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-13-2010, 09:27 PM   #4
gcgordon
Thumbs up Re: 1pc Driveshaft swap 71 SWB Fleet TH350
Thanks LEEVON
Old 09-15-2010, 09:43 PM   #5
gcgordon
Is there a late model 1 pc that swaps in?
Old 09-15-2010, 11:46 PM   #6
Sammy
So many varables as stated above. Best off taking a measurement with a tape and go on the hunt. I ended up getting the last two trucks custom done by a close friend who has welded many a shaft in his day. Your other choice is take the #'s go to a D/L shop expert. That way they can hook you up with the correct u-joints and be balanced for carefree worries.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
