landarts
![]() Join Date: May 2005
Rusty bolt restoration
Has anyone used this product http://www.eastwood.com/ew-rust-dissolver-gallon.html
Or have a different method of restoring old bolts that have rust on them. I do have a sand blast cabinet, however that is a long drawn out process. Any thoughts would be appreciated. |
72 GMC
Re: Rusty bolt restoration
Just get the grease off of them, and then drop them in a jug of vinegar for a few days. Most of the rust will disappear.
Round up everything you want clean, then drop it off at the local machine shop. They'll put it in a basket and acid dip it for just a little money.
$2 or so you can buy a gallon of vinegar// soak bolts for a few days or so, rince with water then a solution of baking soda and they're good to go
strain and save vinegar use as salad dressing for unwanted house guests
#5 | |
1972 gmc c25 292/sm465 dana 60 w/5.13s 1973 vw super beetle 1600cc/4spd(baja bug) 1974 chevy c60 351v6/np-540+2 speed eaton rear 2005 chevy cobalt 2.2l Last edited by 292farmer; 09-17-2010 at 08:51 PM. |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Sorry if the link talks about tumblers. That's what we use on our old bolts. Stick some blasting media in a cheap tumbler and turn it on, and in a couple of days and no effort, they come out nice. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
![]() Join Date: Jan 2001
I have battled this for years on old stuff I can tell you that once the metal is contaminated it can really make a mess. It is not as simple as removing the iron oxides that you can see you must take into account the chemical process that you are about to start, and this is one that you don't want any part of! Do yourself a favor and use Phosphoric acid because it will remove the oxides also but it will start the right chemical reaction that will leave the phosphate coating that will inhibit rust instead of accelerating it. The Phosphoric acid may take a little longer but it is definitely the better way to go, usually the fastest way out of something just leads right back in!
Read this: http://www.ehow.com/how_4487861_remo...from-iron.html Last edited by 69sixpackbee; 09-13-2010 at 11:52 AM. |
#8 | |
Naval Jelly is tried & true.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
Check out this thread Bolt Restorations
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#10 | |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() Join Date: Sep 2001
Why not just buy new bolts? Not being a smart a$$, am really curious.
#12 | |
What?
Plus many times you can not get new bolts that "exactly" match the ones you already have, such as a certain plating, shape, head stamp, length, or ones that have a special washer attached. I get picky about these details when you can see them, or they are serving a purpose that requires an exact replacement. Not that I am all about "Concours d'Elegance" show of my truck, it's just that I tend to be a picky SOB with tiny details like this.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
I am in the same thought process especially the common hardware stuff. Hardware stores sell that stuff by the pound for a couple of bucks or so. And if you not doing suspension stuff, stainless hardware isn't badly priced if you want the shiny sparkling bling.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#15 |
I always use vinegar. They come out looking brand new in just a day or 2.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
#16 |
#17 |
![]() Join Date: Jul 2006
I think I'm going to refinish a couple of bolt buckets that are taking up space. After a little research, it looks like they have good reviews for a cheap vibratory tumbler.
http://www.midwayusa.com/viewProduct...tNumber=158440 Then the caswell plating black oxide kit from the other thread: http://www.caswellplating.com/kits/black.htm
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#18 |
Just want to say that I have not had good luck using a tumbler. I have one and it didn't seem to work (I was using the same media I tumble shell casings in). I have had the best luck with a sand blast cabinet. I would be interested to know how a tumbler would work with a more agressive media.
