Wont Fire.... Need any input....
Okay guys i have a 84 chevy swb with a 400 sbc out of like a late 70's c10..... it ran.... i wont say good but it ran about a week ago... well i changed the spark plugs, wires, and tightened the loose rocker it had.... i got it to fire up one time after that and then i tried starting it again and it backfired hard up through the carb and now will not fire to save my life.... it will crank all day, has spark.... not sure if its a strong enough spark but has it on each plug and has fuel..... i rolled it around to what i thought was top dead center and pulled the cap and it was pointed at the number 1 plug wire.... so i didnt think it jumped timing but every once in awhile it will thump on every cylinder like its barley firing and then when you let off the key it will blubber (no other descriptive word sorry) to a stop..... any ideas??? And i do have electronic ignition but the guy at autozone gave me plug wires from a 78 with points... so im at a loss right now guys
a fool with no money
Re: Wont Fire.... Need any input....
had the same problem with a 4.3 v6. I replaced...wires,plugs,rotor,cap,module and still nothing (although it had spark) ended up replacing the whole distributor (Oreily's) and never had another problem...
does it have spark to ALL the plugs?
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
#3 | |
![]() Join Date: Dec 2008
cant say that i do didn't no if you seen that or not is all and so maybe you could have more input. but from the looks of it, it may be solved.
1962 C-10
Did you pull the distributor? Sound to me like it's 180 degrees off.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Good Morning, Did you over tighten the rocker? Sounds to me like that may be the cause. If it's an intake valve hanging open that would explain the backfire as well as being 180 degs. out. Are the new wires in the correct firing order?
Good Luck and God Bless, Terry :-) |
lol sorry guys this old trucks about to become a half ton boat anchorweight
1962 C-10
You want to adjust the rockers when the valves are in the closed position. Maybe try loosening the ones you tighten and see if it fires. Loose valves are better than overtightened ones. I usually like to do valve adjustments with the engine running. I don't think that will work for you at the moment.
No sir it wont work haha cuz the piece of you know wont even fire
Try moving all of your plugs over 1 to the right on the distributor cap.
#13 | |
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
#15 |
1962 C-10
Good point Adam.
How did you replace your wires? One at a time? Did you rip them all out and start from scratch?
#16 |
It has Spark but will not fire.... idk if my termanoligy is wrong but it is sparking but not igniting the gas to start the engine and i have pulled the plug wires 3 times and redone it
#17 |
![]() Join Date: Jun 2009
1-8-4-3-6-5-7-2 thats ur firing order....should be casted into the manifold. backtrack and "untighten" the rockers you tightened. (back them off a hair) i agree with everyone else that it sounds like ur 180 out.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
#18 |
did you loosen or move the distributor? pull #1 plug out and roll the crank until ur top dead center. check ur rotor to see where its pointing. check ur timing tab and make sure its lined up with the balancer..
#19 |
Chevrolet / Chevy Engines: Rotation: Clockwise Firing Order: 1-8-4-3-6-5-7-2
#20 |
okay guys i appreciate the help ill try it on friday i work 6pm to 6am so ill see what i can do..... ill loosen them and try firin it up
#21 |
Did you pull the coil out of the distributor cap?
#22 |
Damn I didn't see that til now. The pic of the rotation on the distributor is wrong. Just move the 1 to the left and continue cw. Sorry
#23 |
Im heading today to loosen my rockers and try to get it to fire.... im gettin frustrated with this old truck.... i wish i knew more about what the previous owner did to the motor
#24 |
Did you replace the plugs with auto lites? I just had a similar problem and it was caused by the sparkplugs. They looked like they were firing but were not. Another thing to check is power to the distributor. Make sure you have about 12.5 volts. You probably do not if you have been cranking on it for a while.
#25 |
Is that diagrame the same for a 87 silverado
