Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-15-2010, 10:06 PM   #1
chucks70
stuck in 4 lo
Finally finished putting an engine in '99 Blazer. Got discouraged with it around May and let it sit until a couple of days ago. Everything looked good, started right up, engine runs fine. Drove it out the road, tranny shifts fine. Only thing is it is stuck in 4 wheel lo. When I turn the key on, there are a couple of clicks under the passenger side dash or kick panel. Has automatic shifting system for the transfer case, does the computer possibly need reset, new TCCM, stuck shifting mechanism? Any ideas on how to check what may be wrong? Any other ideas?
Chuck
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 09-15-2010, 10:39 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: stuck in 4 lo
To shift out of 4lo you have to be in neutral.
How did it get stuck in 4lo? Did you put it in, or did it do it itself?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-16-2010, 07:44 PM   #3
chucks70
Re: stuck in 4 lo
After I got the battery in and started it up it was in 4-lo. I have put the tranny in neutral, tried pressing 2w hi and 4w lo at the same time to get the transfer case to shift into neutral which didn't happen. I've tried rocking it back and forth and also drifting backward in neutral trying to get it to change.
Chuck
Old 09-18-2010, 07:26 PM   #4
chucks70
Re: stuck in 4 lo
Well, got it to shift out of 4 Lo. Noticed that the shift position indicator on the dash wasn't working correctly. Checked the connectors on the tranny, they were tight. Just started running the shifter through the positions several times and it started lighting up. Must have gotten some corrosion on the contacts in the position sensor or something. Anyhow, put it in neutral with the indicator light on and it shifted out of 4 LO.
Chuck
Old 09-19-2010, 12:10 AM   #5
67ChevyRedneck
Re: stuck in 4 lo
Sweet man!
Jesse James
Project "On a Dime"
Old 09-24-2010, 07:00 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
Re: stuck in 4 lo
these shift motors get grumpy if not used regularly.
if you decide to replace one avoid Dorman (high failure rate on the sensor).
68C15 is offline   Reply With Quote
