09-17-2010, 05:04 AM | #1 | |
Conversion Truck Addicted
TBI 87 350 to 454
Im going to build a 454 with tbi for my heavy hauler project. but can i take a throttle body, wiring harness and ECM from a 350 truck?
Thanks Thomas
Thomas Quote:
09-17-2010, 07:25 AM | #2 |
Re: TBI 87 350 to 454
Harness is fine, ECM will need a reflash.
The throttle body will be too restrictive, your 454 will be breathing through a straw. Find a good rebuildable 454 throttle body and go from there. |
09-17-2010, 08:21 AM | #3 |
Formerly- 1972SuperCheyenne
I agree. The 5.7 TBI will kill that 7.4
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-18-2010, 02:48 PM | #4 | |
Alternately BBC IAC uses GM#12126487; AC-Delco #PT757 or Pico-5602 pigtail. The 1227747 ECM uses 2732A UV PROM chip (which is not the same as FLASH) - which is notoriously prone to failure! The easiest way to get around this 25+ year old chip is to install modern Flash chip AT29C256 or 27SF512 in G2 adapter. For detailed information see http://www.moates.net //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
09-17-2010, 09:24 AM | #5 |
BAD BOW-Silverado XST
Call this company to upgrade your TBI.
http://cfm-tech.com/GM_tbi_tuning_tips.htm |
09-18-2010, 04:51 PM | #6 |
^ forgot about the IAC connector when we used a 454 TBI on my son's 383 vortec stroker conversion. Seems like there was one more wire that was different but I can't remember what it was...
09-18-2010, 05:56 PM | #7 | |
The correct wiring for the 7.4 IAC valve is as follows : ECM Con Color C3 Pin A Lt blu/blk - Coil A Low C4 Pin B Lt blu/wht - Coil A High C5 Pin C - Lt grn/wht - Coil B High C6 Pin D - Lt grn/blk - Coil B Low
