09-17-2010, 07:18 AM | #1 |
p/s question
Can I use the p/s box from my donor 85 c10 on my 65 suburban? see lots of talk about changing the suspension but no mention of the p/s box...will it bolt up to the frame and column??
09-17-2010, 09:54 AM | #2 |
UCA63
Re: p/s question
I believe there's a talk on it in the FAQs
T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
09-17-2010, 11:46 PM | #3 |
fan of "Butters" Stotch
Re: p/s question
It may be easier to use a column off a newer truck.
Also, talk to Captain Fab about a bracket. Here is a link that could help as well http://www.persh.org/pickup/IdeaPage.htm look in the "modern power steering" section
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again Last edited by tapeworm; 09-17-2010 at 11:49 PM. |
09-18-2010, 12:48 AM | #4 |
60-66 Nut
Re: p/s question
You will need an adapter plate to mount it to the frame, and you will need to shorten the steering shaft on the column.
