Old 02-25-2003, 10:14 PM   #1
Bowtie468
Bowtie468's Avatar
Disc rotor question/availability
Anyone know if i can buy new rotors ( '71 - '72 ) with 5 on 4 3/4" bolt centers. I'd prefer not to re-drill if at all possible. I'm quite sure i've seen them available somewhere, just can't remember where !
Chris
Bowtie468
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 02-26-2003, 09:09 AM   #2
smokekiki
Mike
smokekiki's Avatar
You should be able to get them at your locale parts store.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-26-2003, 10:40 PM   #3
Bowtie468
Bowtie468's Avatar
Okay, i've been checking on this since i first posted it a couple days back. I did find the rotors that i had seen before, but the way the salesman described it to me, i wasn't impressed at all, to say the least. This was on a conversion kit ( drum to disc ) from Brothers and from what the guy said, they use car rotors (probably 10 ") for the conversion which is why they showed 4 3/4" bolt centers. I talked to a few others after that and have come to the conclusion that my only option is to re-drill my rotors for the 4 3/4" bolt pattern
Chris
Bowtie468
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 02-26-2003, 11:03 PM   #4
hobby67stepside
I'm thinking I got 11" rotors 1 1/4 inches thick with the 4 3/4 bolt pattern at the local Car Quest outlet. Its been awhile , but I think that's correct. They were made in China which I didn't care for. I'm not concerned about quality, I just don't like supporting communists.
  • '05 2500 HD Silverado 6.0 liter
    '97 2500 4X4 454 eng
    '92 2500 4X4 350 eng
    '78 K20 4X4 400 eng
    '70 Boss 302 (owner for 27 years)
    '57 Ford shortbox 383 stroker TH350 tranny
    '23 T-bucket (built in '78)
    '02 Explorer
    '67 C-10 short step
NW Iowa
hobby67stepside is offline   Reply With Quote
Old 02-27-2003, 02:32 AM   #5
Duallie
Duallie's Avatar
I have an avenue you could check out.....
I remember looking at a late-70's station wagon for its HD 12" brakes (5 on 5"), and thinking "hey, thats the same casting number as a 1/2 ton 2wd" AND I know that the wagon rotors are swappable onto 3rd gen Camaros (except for the bolt pattern) BUT are otherwise the same as 1LE heavyduty brakes on '87?-'91 Camaros (which ARE 5 on4 3/4") SO maybe they'll work on a pickup spindle. AFTER you saw off the existing caliper mount and see if the 1LE caliper bracket can be adapted. Don't forget you will need a QuickTakeUp master cylinder (QTU) to match the modern seals in the metric calipers.
Could be an expensive experiment. But it might fit!
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
