`62 Panel...Chiquita
New member, new project! Awesome site here, lots of info. Hopefully I'll be able to add to it once the ball is rolling.
2 weeks ago I pulled a banana yellow `62 GMC panel out of a run-down garage and I guess this will be the build thread! It has a 235 Chevrolet (Canadian GMC mill) with a 3 on the tree, bare bones-no nothing. Needs rockers, hood and the motor is stuck from sitting. Inside is mint. Hopefully I'll get it running before the snow hits if not it will have to wait until spring. Plan for now is to get it running, the rust cut out and patched up and get it safe to drive. After that I'll drop it and swap in a 73-87 front suspension with disc brakes. I happen to have a smallblock looking for a new home although I'm tempted to build up the 6 it it is decent after teardown. It will stay 60's style, a cross between a mooneyes shop truck and a surfboard hauler... |
Re: `62 Panel...Chiquita
She followed me home....
![]() Join Date: Jul 2010
keep that color..
60-66 Nut
Nice find. Looks to be decent except for the hood and the rockers you mentioned. Keep us posted.
chevy only
![]() Join Date: Sep 2006
Holly cow a gmc panel very cool !!! Nice find kat!!!
CHEVY ONLY... Nothin Else ! |
looks like an awesome start! make sure to take lots of pics
1960 short bed fleetside factory 4x4 1960 panel 454 NV4500 Daily driver 1961 Short Bed BBW Fleetside 5.3 th400 swap in process |
UCA63
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Did it once belong to Robert Transport, looks like their crest on the door. The hood is still here if your interested, I also have a chrome GMC grille.
Local website that might interest you. http://vieuxpick-up.forumactif.com/portal.htm
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 09-20-2010 at 05:57 AM. |
aero...it nver belonged to Robert however the previous owner rented it out for promotions once in a while, it was lettered with several company logos. Gotta clean off the glue leftover.
I'll pass by to see you sometime this week as soon as I get the brakeline changed on my K20...can't fit the hood in my car! |
Tot Roddin'
Nice!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
1962 C-10
Nice!! I can't wait to see progress...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
I've seen a 64-66 GMC 960 in Ville St Laurent that has a primo hood on it. It's on the road beside the airport, Chemain St Francois. The company does snow removal but I've never seen this truck in motion, wonder if they would sell the hood or exchange it. I saw this truck in the same spot in 97 before I left for Vancouver BC.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 09-22-2010 at 08:00 PM. |
Aero....thanks I'll have to check that one out sometime! For now I think yours will get me by cruising until I hit the body stage.
As for a little update, there are some stuck rings. I pulled the plugs last week and filled the cylinders with the best penetrating oil from work (I'm a heavy machinery tech), repeated again tonite. Trying to come up with a way to get a breaker bar on the crank pulley....it doesn't have a cross-shaped hole in the center like my buddy`s 235 from 1954. I really don't want to put a chain wrench on the damper.... I got the paperwork ironed out today and found a place to store it for the winter. Here`s a pic of the motor...before i started... |
WOW it's been almost 2 years since that last post. UPDATE...I pulled the truck out of storage this spring (April) and had no luck getting it to turn over, started opening up the motor and found rust everywhere....realised it had to come out...
#15 |
Here's a pic of the mess...
#16 |
I didn't even consider rebuilding the original motor...I threw around the idea of a V8 swap (I have a 350 ready to go) but have little (or no) time these days to fabricate and scrounge parts for the swap. I looked at everything from v8 parts trucks too far away and too expensive to ''ran when parked'' 235's in barns that looked worse than mine. I would search craigslist and Kijiji to no avail. until this popped up for sale not too far away......
#17 |
It popped up while I was searching ''235'', sure enough, under the hood is a 1957 Chevrolet truck 235.
Way WRONG swap done on a farm when the truck's 4.3 gave up and there happened to be a 235 in the shop from an old farm truck. Angle iron from the scrap bin, a torch, a welder and odds and ends, you get the idea led to this abortion.....Check out the front motor mounts. I drove it home..... |
#18 |
cool find and what luck on finding the 235..
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#19 |
Good looking panel, and those engine mounts are sad.
Posted via Mobile Device |
#20 |
UCA63
How did the YJ tank swap go ?
That sounds like an available/affordable choice. What sending unit was used ? T
