#1 | |
Conversion Truck Addicted
Converting to 4WD
i have plans for building a Flat bed Hauler out of my newly purchased 2WD 86 Crew Cab.
but i would really like to have it converted to 4WD because i will proberly come into situations where i would need it with this heavy truck like wet grass, mud or snow but i would like to keep the the stock 2wd hight maby even lower it some so going to a solid front axle Dana 60 or 70 is proberly out of the question so i thinking the K3500 88-98 trucks had Indy Front suspension with CV Half Shafts, could i take the complete suspension and move it over to my 86 chassie or would i be better of buying a 88-89 Chassie and mod the cab mounts for my cab? because then i would also have ABS brakes also building a frame from the ground up has also been a though whats your thoughs on this would i even need the 4wd? ![]()
Thomas Quote:
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: Converting to 4WD
I'm sure it can be done. GM made millions of 88-98 crew cab 4x4s just to be hacked! Go for it.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Subscribing.....interested to see what route you take.
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original. View Project Pops HERE Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig View Project Cletus HERE - SOLD DD--2008 Duramax CCSB |
I would say the easiest would be to swap the frames and make your own body mounts. That's probably the cheapest also. But then I hate IFS and would always pick a solid axle over it with out even blinking.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
#5 | |
i would too but i just think the solid front axle would make it too high, top heavy and cant take lowered carsntrucks
Thomas Quote:
#7 | ||
Thomas Quote:
You can make a solid axle ride very low. I have seen 4x4 drag trucks that were on the ground, you just have to fab up some front end parts. Grab you a Dana 60 and a N.P.205 and go for it.
Put in an Inline 6 diesel and mount it all the way over to one side.... hopefully the diff would clear the oil pan then.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#10 | |
naa 454
Thomas Quote:
My dad lives where it snows like crazy and is always muddy, his former custom bad ass 76 2wd is now a workhorse and he gets by without having 4wd with the correct tire. He bought some tires with crazy deep lugs for the back and is just fine.
