09-25-2010, 04:44 PM | #1 |
69 Camaro Gas Tank Install
I have been wanting to install a behind the license plate tank since I bought my truck. I took this as an opportunity to help anyone else who may want to go this route.
Mods - If this need to go someplace else - no problem with me. Here goes....... I bought a 69 Camaro gas tank(18 Gallon), sending unit, straps and anti, squeak kit from a company off of E-bay by ther name of Tamraz for 194.00 shipped. Don't order off ebay, just call the company tell them about the forum and this install and they "may" cut you a deal. Don' bother with the 69 Camaro gas tank straps. It's easier to fabricate your own than use theirs. See if they will swap out the straps for the anti-squeak kit. Their # is 1800-442-4601 Here is a list of other items needed: Flip down license plate holder - 10.00 U-pull 6 ft metal tubing 2"x3" and 8' of 1"x 1/8 strapping - $30 at steel distibutor 10' 3/8 tubing, 4' rubber fuel line, locking gas cap, union for tubing - 32.00 @ Autozone Misc hardware to mount tank to frame and fuel line - $10 at hardware store Total about 276.00 [IMG][/IMG] I started by mocking up the tank to the frame to see how much of a spacer I would need with my bumper [IMG][/IMG] [IMG][/IMG] Once I got the right height I took off the license plate bracket and cut out a square with the cut off wheel, drilled a couple of holes in the bracket and mounted the flip down holder. [IMG][/IMG] I cut the 2x3 square, drilled the holes and mounted it to the frame. After that I cut the 1x1/8 and bent them into the shape of the tank, drilled holes and did a test fit. [IMG][/IMG] Put everything in place and slid the anti squeak pieces in, tightened it all down. [IMG][/IMG] Took out the old tank and fuel lines and pre-bent the new lines to match the old one. [IMG][/IMG] Then installed the front portion using the old clips. Installed the back portion with some new clips and hoses. [IMG][/IMG] [IMG][/IMG] I still need to hang the exhaust so that it doesn't hit the tank and smooth the old gas neck hole but that will be another day. Here is the finished product. [IMG][/IMG] I have to say thanks to Bad70sbchevy, without his pics and info none of this would have gotten done. This is truly his build I just detailed it a bit more. I took a bunch more pics and they are in my gallery if you want to check them out. Matt
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 09-25-2010 at 05:28 PM. |
09-25-2010, 04:49 PM | #2 |
Its always something!
Re: 69 Camaro Gas Tank Install
I never thought of using a camaro tank. Thanks for sharing!
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
09-25-2010, 04:54 PM | #3 |
How well does it fill?
09-25-2010, 05:10 PM | #4 |
AWESOME! Thanks for the write up and pics. I plan on doing this as well. . Very clean!
09-25-2010, 05:25 PM | #5 |
Just filled it and it fills great.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
09-25-2010, 05:54 PM | #6 |
Grandpa in the rustmobile...
so thats the original filler area? Does it leak or anything?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-25-2010, 06:09 PM | #7 | |
A whole lot of '60s to mid '70s GM cars were like that.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
02-22-2011, 12:30 AM | #8 |
Old Skool Club
...along with some others from the '50's. FoMoCo cars had the filler like that in '52. But, A-bodies and F-bodies had the tanks and fillers like that. 1st gen Mustangs used the top of the gas tank for the floor of the trunk, unlike Camaro/Nova, etc. But, the filler of the GM tanks are more horizontal than the FoMoCo vehicle gas tanks, which use a rubber hose-type connector to join the gas tank to the filler pipe.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
02-24-2011, 09:08 PM | #9 |
I have a gas tank out of my 69 chevelle. Im going to put a new one in it. I wonder if my old tank will fit under my 64 C10 truck like the camaro one does.
69 chevelle malibu, 64 C-10 shortbed |
09-25-2010, 06:03 PM | #10 |
Thats sweet; I grew up with a '79 TA in the family and thought that was the coolest thing at the gas pump. I have another idea to add to the list . Any concern with ground clearance it looks kinda low. What is the ride height of your truck? Thanks.
09-25-2010, 06:18 PM | #11 | |
No leaks!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 09-25-2010 at 06:19 PM. |
09-25-2010, 08:26 PM | #12 |
that's a great idea. let's put this in the tech section
09-26-2010, 10:32 AM | #13 |
looks great,nice job, and pictures
09-26-2010, 04:18 PM | #14 |
I wonder what other years that 69 GM Camaro tank will interchange with??
Always looking for a different source for a part. Camaro equals expensive, 78 Nova equals not so expensive.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
09-26-2010, 04:46 PM | #15 |
What a great idea.Been kickin around what to do with my. This is the best one so far. Tank out of the cab and still has a factory look. Nice install. Thank for sharing...
Mr. Breeze |
09-27-2010, 02:43 PM | #16 |
Thanks man, that thing turned out clean. Great job.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car Last edited by Bad70sbchevy; 09-27-2010 at 02:45 PM. |
09-27-2010, 07:54 PM | #17 |
Good write up and pictures. I'll have to do some measuring to see if it will clear a short bed 4x4.
ROD 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
09-28-2010, 02:41 PM | #18 |
67Slider thank you for shareing... Im on a low budget and will have to go this route... Nice set up vs the 700 fuel cells... hey they stick out too... still looks clean... Nice work ! ! ! Having the tank in the cab makes me nervous... especially cause our trucks tend to get t bonned... nock on wood... Thanks again 67Slider !
09-28-2010, 08:26 PM | #19 |
WOW! I like the look, give a factory look to it. I've already installed the blazer tank, but had I seen this first I would have done this. It would have saved me the hassle of putting a gas door in the side of the bed!
09-28-2010, 08:44 PM | #20 |
Great write up and initiative to try something new!
Do you have any pictures of your Camaro tank installation from the side or back, from a distance and with the bed installed? Seems like the tank is hanging down really low... same look as the blazer style tanks. I recessed a 1949-52 Chevy tank into my '65 'cause I really didn't want to see the tank hanging below the bumper or visible from the side of the truck. Last edited by lakeroadster; 09-28-2010 at 08:55 PM. |
01-11-2011, 09:36 AM | #21 | |
71 gme Sierra Grande lwb. 68 Rambler American 2 door 75 jeep cj5 |
09-28-2010, 09:01 PM | #22 |
I haven't put the bed back on. It is still in the "in work" stage. I wil try to take some pics from the side tomorrow.
09-29-2010, 06:36 PM | #23 |
I got some pics of the back of mine with stock lift.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
09-29-2010, 06:54 PM | #24 |
That looks nice Bad70. I think I might try this instead of a putting a hole in the side or in the bed.
ROD 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT Last edited by Rodk65; 09-29-2010 at 06:55 PM. |
09-30-2010, 07:39 PM | #25 |
Thanks, thats the exact same reason why I didnt want to use the blazer tank.
