Old 09-26-2010, 12:42 PM   #1
into69z
"brand new second-hand"
into69z's Avatar
how does the clutch fan work?
I want to know if anyone knows how to test a stock fan clutch? I had a few trucks, an 86, 89,and 96 all 3/4 ton with big block and heavy duty cooling. When those fans locked up, it sounded like you were turning 10,000rpm-till they cooled off-then back to normal. I have my 69 with a big block and the 4 row radiator,a/c, seven blade fan and a new fan clutch. I don't over heat until I get into stop and go traffic-it does not boil over,just the temp gauge goes to the middle. Are the fan clutchs all the same or are the newer ones designed diffferent? would the new ones fit the old trucks? How can I tell if my new clutch is performing correctly? Anyone have any idea about how much cfm's are produced with the stock system?
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 09-26-2010, 01:20 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: how does the clutch fan work?
If it doesn't boil, I wouldn't worry about... it's not overheating. Better units have a bimetal thermostatic spring on the front.
Here's a couple sites with good info:
http://www.2carpros.com/how_does_it_..._fan_works.htm
http://www.aa1car.com/library/cooling_fan_clutch.htm
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-27-2010, 03:22 PM   #3
into69z
into69z's Avatar
Thanks! Stocker-Steve
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 09-27-2010, 03:38 PM   #4
msgross
msgross's Avatar
You could replace it with a non-clutch fan or add an electric fan to assist your mechanical setup
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-27-2010, 04:14 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Assuming a proper clutch fan and a good cooling system -- including a shroud -- in theory it shouldn't overheat. If it does, adding an electric ought to do the trick for sure. But I would personally never replace a clutch fan with a fixed mechanical fan.... just my opinion.
- Mike -
RIP El Jay
