Old 09-26-2010, 05:53 PM   #1
turner72
Need Help
Not sure if this is a problem or not. I have a 71 350/350 with the LMC dual exhaust with glasspack style mufflers. When you let off the gas at speed I get kind of a blatty backfire sound from the exhaust. Other than that the engine runs great. Is this normal with the glasspacks?
turner72 is offline   Reply With Quote
Old 09-26-2010, 06:14 PM   #2
Lee H
Lee H's Avatar
Re: Need Help
Could just be the sound of your glass packs. A backfire in the exhaust on deceleration is usually do to a leak. Recheck all your connections.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-26-2010, 08:06 PM   #3
JimKshortstep4x4
Re: Need Help
If you used the light duty clamps that are furnished with the set then that may be your problem. The pipes have fairly heavy walls and heavy duty clamps are need to clamp the pipes together.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-26-2010, 09:00 PM   #4
swamp rat
swamp rat's Avatar
Re: Need Help
I'm not a fan of muffler clamps, welding is the way to go, recheck your manafold gaskets too.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
