09-29-2010, 02:09 PM | #1 |
Computer trucks what's your water temp range?
I did a search and failed to come up with much of anything. I was wondering what kind of water temp range everyone's seeing on their factory guage (or otherwise) with the computer controlled (TBI) trucks? As I recall the early TBI/TPI stuff ran fairly hot from the factory.
I'm standard at 210 but sitting at a light (in gear) it will creep up to the 230s pretty quick. If I shift into neutral, it'll hang at 210. I recall that 210 is pretty standard, but wondered what everyone else sees.
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
09-29-2010, 02:11 PM | #2 |
Re: Computer trucks what's your water temp range?
Mine's freezing (but it's a V6, if that makes a difference).
Runs pretty much 180 degrees no matter what. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-29-2010, 02:49 PM | #3 |
Cruzzzn' Vet
I put a 180 deg thermostat in my CC 83 silverado and that's the temp it stays in most of the time, warms up with the AC to about the second line on the gauge but has never gone over the 210 mark, and running the electronic Qjet.
09-29-2010, 05:09 PM | #4 |
All About the BOWTIE
x2
CaliDude76 "... Being "SQUARE".. is where it's at...." Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
09-29-2010, 08:31 PM | #5 |
Mine creeps up to 210, then the thermostat pops open and it drops to 160-170 and never moves.
09-29-2010, 09:08 PM | #6 |
Mine runs at 180.
Andrew 1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10 1988 C1500 Scottsdale 305, 700R4, 3.08 1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10 |
09-29-2010, 04:27 PM | #7 | |
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
09-29-2010, 10:35 PM | #8 |
I have the clutch fan and what appears to be a stock electric fan. The electric fan runs when it goes over 210. It appears to have a 4 row rad in it. Wonder if I could have a blockage. Seems like I am running hotter than normal compared to you guys.
09-29-2010, 11:12 PM | #9 |
Its not on a computer controled emgine, but its what mine runs at.
It runs just a bit lower then that and when it hits temp it wont move. |
09-29-2010, 11:49 PM | #10 | |
X2 with tbi drove it back from virginia 80-85 most of the way and ran 210 all the way up but have since replace thermo was stuck open Posted via Mobile Device
1987 R10 Silverado - Rusty But trusty Daily 1984 C10 Custom Deluxe - Newest Project |
09-29-2010, 11:20 PM | #11 |
running with no thermostat and electric fans mine runs at 180
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 |
09-30-2010, 10:00 PM | #12 |
You know no thermostat makes your motor run insufficient? Just thought i'd pop in, tryin to help
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552 2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html |
09-30-2010, 12:24 AM | #13 |
Thanks guys. I appreciate it. I'm going to change the thermostat. I wonder if that's the deal. Might be stuck open. Gotta start somewhere?
09-30-2010, 08:39 AM | #14 |
When driving I am at 180 but when stopped it goes to 210 to 230 but then back down. I am going to go with dual electric fans and that should solve it. Even though it's not a problem.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
09-30-2010, 05:54 PM | #15 |
yea, when i bought mine, the tbi 454 ran at 210 and would creep to 230 or so in traffic. i put a 180 thermostat in it and it runs so much better.
