09-30-2010, 02:42 PM | #1 |
uh oh
engine tickin (loudly) right along with acceleration.....please oil change do the trick.....fingers crossed.
76 Chevy Fleetside 63 Lincoln Continental w/ Ford Racing 460 (550hp) 2012 VW GTI 2013 Escalade 2008 Harley |
09-30-2010, 03:12 PM | #2 |
Re: uh oh
That sucks man, its not a rocker?
09-30-2010, 05:22 PM | #3 |
Re: uh oh
not quite sure yet.....
09-30-2010, 05:32 PM | #4 |
Re: uh oh
never order a repair manual before....how are chiltons? anyone use?
09-30-2010, 05:38 PM | #5 |
Re: uh oh
Chiltons don't impress me. I go for factory manuals.
09-30-2010, 05:49 PM | #6 |
Re: uh oh
whoops....ordered the chiltons...oh well prob will suffice
09-30-2010, 09:09 PM | #7 |
78K & 79C Jimmys
Re: uh oh
i've used duralube during an oil change and it helps get rid of ticking in some cases
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-30-2010, 09:15 PM | #8 |
Re: uh oh
I go for factory manuals. all so
09-30-2010, 09:18 PM | #9 |
Re: uh oh
Mine makes some unfriendly noise in the upper RPMs. At this point, I'm gonna check the valve train one more time. If it all looks good, I'm just gonna run it till it pukes.
09-30-2010, 10:27 PM | #10 |
Re: uh oh
Might want to try using a thicker oil and Motor Honey additive, it really made a difference in my truck. Also see if you are getting blow-by (is it leaking oil from the gaskets? popping the pvc?) I was able to fix a lot of my problems by getting an oil fill breather cap and using 10w40 oil. I know the oil's a band-aid, but if it's a 30,000 mile band-aid that's 2 years with the mileage I drive.
09-30-2010, 10:50 PM | #11 |
Re: uh oh
Are you sure it's not an exhaust leak?
10-01-2010, 08:01 AM | #12 |
Getting Old; Going Broke
Re: uh oh
Was my thought as well. I had an awful tapping noise with only 200 miles on my engine. Found the left header had a bolt missing, 1 finger tight and the rest barely holding on.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
10-01-2010, 12:49 PM | #13 |
Re: uh oh
I would also check for an exhaust leak. If you can't hear the tick at idle or low RPMs, but you can hear it under load, that's a good indication of a leaky exhaust manifold gasket.
10-01-2010, 12:55 PM | #14 |
Re: uh oh
thanks i will look at the manifolds tomorrow
