10-01-2010, 06:57 PM | #1 |
Wiper arm removal
OK...first, I read all the posts about getting the arms off using a screw driver, that didn't work. I then bought the wiper arm removal tool from snapon, but I guess I just can't figure out how to use it. It seems pretty simple, but I don't know where to insert it, front or back side, to release the clip, or which end to use. Can anyone help?
1969 Chevy K20 Custom Camper 350, 4sp, 33's High on plans, Low on funds |
10-01-2010, 08:43 PM | #2 |
Active Member
Re: Wiper arm removal
Are you trying to take off the entire are down at the stud?
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
10-01-2010, 10:14 PM | #3 |
Cruzin
i just poped mine off yesturday, i just take a screwdriver and slide down the little clip and it should work off the shaft if not just use the screw diver the gently push up on them, just lay something on you cowl if you have nice paint
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
