10-01-2010, 08:12 PM | #1 |
It followed me home?
Another coil cutting question, or heating to tweak?
So I cut a full coil off my dually and I think it still needs to come down another 1". Can I cut just a 1/2 coil off? If I do that it the bottom of the spring wont sit in the pocket right, is that ok? I know that heating coils for drop is a no no but is it bad if all I need is 1"
Or Do I just pony up some $$ and buy some 3" drop coils? I realize thats probably the best option but like everyone else I want to get out of this as cheap as possible
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 10-01-2010 at 08:15 PM. |
10-01-2010, 08:17 PM | #2 |
Re: Another coil cutting question, or heating to tweak?
take em out and cut em again..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
10-01-2010, 08:28 PM | #3 |
so it's ok that they wont line up with the pocket in the lca?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-01-2010, 09:16 PM | #4 |
just rotate the spring so the last of the coil sit in the little channel
10-01-2010, 09:28 PM | #5 |
That doesnt work because the top of the spring pocket is ovaled
10-01-2010, 09:31 PM | #6 | |
67-72 parts collector,…
This is what I've tried to say on here before, in another thread. Line up the top,... don't worry about the bottom.
10-01-2010, 08:35 PM | #7 |
I say YES.
Others say no. But I've done it at least a half dozen times.
10-01-2010, 08:42 PM | #8 |
I bought new lowered springs and the don't fir in the pocket.
big old burb in primer.lot of work to do. |
10-01-2010, 09:38 PM | #9 |
I've read somewhere where certain types of front coil springs are unsafe to cut. But that was a place that was selling lowering parts. Lol. As far as I would go is the 2 inches you already have, and be safe. So the 3 inch drop coils would be the thing to do. No guessing that way. You'll know whatcha got.
10-01-2010, 10:05 PM | #10 |
1/2 coil= 1" drop,... as a rule,... but not a for sure. Ha.
If you think it will be too much,... cut 1/4 coil. When it's all said and done,... the coil will be a "given" length. And it will only compress so much. The only way to screw up,... is to not get the top seated. I ususally lay on my back and verify the spring is seated in the upper "D" shaped retainer. I also mark the front of the spring with a marker or tape. This will help verify the spring hasn't rotated while you are messing with the lower a-arm and balljoint. Don't install the shock or the sway bar until you are happy with the ride height. And,... we need pics!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-01-2010 at 10:06 PM. |
10-01-2010, 10:14 PM | #11 | |
10-02-2010, 03:35 PM | #12 |
Cruzzzn' Vet
1 complete cut coil is 2" in drop
