Old 10-01-2010, 08:35 PM   #1
repeeler
repeeler's Avatar
Help replacing window regulator
I am trying to replace the passenger window regulator in my 71. The service manual says: Wind widow all the way up; remove 4 screws; Push regulator out of circular opening; slide assembly to the notches in the carrier and out thru the door access hole.
When I try to push it thru the hole it is hitting the window track that is right behind it so I can't get the shaft to clear the hole. Am I missing something?
Ray
1971 Cheyenne LWB
1965 C-10 Short Fleetside 350/350
2010 Harley Davidson FLHTK
repeeler is offline   Reply With Quote
Old 10-01-2010, 08:42 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Help replacing window regulator
You can unbolt the back channel from the door and it will give you more play for the regulator be careful about the glass though.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-01-2010, 08:48 PM   #3
Sammy
Not sure how the book is saying to do it. If you get someone to hold the glass to prevent it from falling at the top edge, I just unscrew the mount screws then slide the rollers out of the track work it out the hole. Reinstalling it is slightly more difficult and it's easier for me to put the rollers into the track have someone hold the window to keep from dropping it, slide the regulator over and align the mount screws by cranking the regulator so the window is about half way up or so it seems easier for me. Hope I helped you and not confused you.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-01-2010, 08:50 PM   #4
Sammy
Maybe it's the part about rolling the window all the way up thats got you. Try half way up. but get someone to hold the glass.
Old 10-01-2010, 09:29 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
suction cups on a string works great for window work i had made one up when i work for ford dealership and doing flat rate work on window regs. isnt fun.i would put the window up until the roller our out to the farest part of the track if you go to far up then the rollers come back on the track,
i got a feeling im going to be reading your post on battle wounds soon ---j/k
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-04-2010, 08:20 AM   #6
KEL
72 GMC
KEL's Avatar
simple wooden shims on both the inside and outside hold the glass up for you too.
KEL is offline   Reply With Quote
Old 10-04-2010, 03:14 PM   #7
repeeler
repeeler's Avatar
holdoing up the window is not the problem I am having. The issue is when trying to get the regulator out, I cannot get the shaft of the regulator to clear the hole to pull it out because it is hitting the front window track. Am I going to need to remove the wing assembly to get this thing out?
Ray
1971 Cheyenne LWB
Old 10-04-2010, 03:57 PM   #8
sameyrasmea72
sameyrasmea72's Avatar
I thought the vent window had to be taken out first. That is the way I have done it, but I am not positive.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 10-04-2010, 04:12 PM   #9
john
member #16
john's Avatar
This might help. It shows vent removal.
http://www.67-72chevytrucks.com/vboa...d.php?t=157539
john is offline   Reply With Quote
Old 10-04-2010, 11:06 PM   #10
repeeler
repeeler's Avatar
I went ahead and removed the vent window assembly and was able to get the regulator out. Got the new one in and the door all reassembled. Now back to my original task, installing the old air system.
Ray
1971 Cheyenne LWB
