Old 10-01-2010, 10:59 PM   #1
Razr
fuel gauge resistor
hello I was wondering if any one can post apic if the fuel gauge resistor brcyzu think mine went bad and I need to replace it... another question how can u test if it is bad thanx
Razr is offline   Reply With Quote
Old 10-02-2010, 01:17 AM   #2
capev86
Re: fuel gauge resistor
i am wondering also. my fuel gage reads well beyond the full mark (straight to the right). i moved the needle back when the cluster was apart for tach and vac install and it went right back to 3 o'clock that first time i hit the key.
capev86 is offline   Reply With Quote
Old 10-02-2010, 01:32 AM   #3
Dark Knight
Dark Knight's Avatar
The resistor is a part of the sending unit. A new sending unit must be purchased because the resistor itself in non-replaceable.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 10-02-2010, 01:47 AM   #4
justtime520
justtime520's Avatar
same problem. just replaced sending unit and some fuses works perfect for more than a year now. if i remember i bought a resister from a board member (thought it was the problem). however it work fine so didnt replace it
justtime520 is offline   Reply With Quote
Old 10-02-2010, 02:58 AM   #5
eagleuh1
eagleuh1's Avatar
Try doing a continuity check on the wire first. It might have a break in it somewhere. It pegs when it becomes disconnected at the fusebox also. At least mine did. Good luck.
eagleuh1 is offline   Reply With Quote
Old 10-02-2010, 03:09 AM   #6
Razr
what do u mean it might have a break in it sumwhere...
Old 10-02-2010, 03:52 AM   #7
eagleuh1
eagleuh1's Avatar
The wire might be broken inside the insulation. Connect a multimeter to each end and do a continuity check on it. This will tell if the wire is good still, and the connectors are good, still attached to the wire.
Old 10-02-2010, 08:59 AM   #8
sjarrett71
sjarrett71's Avatar
My wire had many breaks and exposures in it. I clipped both ends of and spliced another piece of wire between the two terminal ends, almost the full length. Gauge still didn't work. I then took my sending unit out and realized my float was full of fuel.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 10-02-2010, 01:20 PM   #9
Razr
well mine has the wire connected with wire nuts ...my tan wire goes from the sending unit to the gauge but in the middle the wire is joined together with a wire nut may this be a problem.
