Old 10-02-2010, 08:44 AM   #1
johns truck
rear end
what rear end will fit my 53 3100 ? please help!
johns truck is offline   Reply With Quote
Old 10-02-2010, 11:10 AM   #2
Wheelie
Re: rear end
Direct bolt in an s-10 rear is going to be the closest.
Wheelie is offline   Reply With Quote
Old 10-02-2010, 03:16 PM   #3
raycow
Re: rear end
Any 1/2 ton truck rear up to about 69 will be very close to stock width and will let you keep the 6 lug pattern, if that is important. You might have to move the spring mounts though.
The S-10 rear is quite a bit narrower than stock, but would be good if you are going after the deep wheel look.
Ray
raycow is offline   Reply With Quote
Old 10-02-2010, 03:42 PM   #4
Indian113
Indian113's Avatar
Re: rear end
Not really a dumb question, a lot of rear ends will fit here is my 53 with a 74 nova rear end. I am using 8inch wheels with 4 inch backspacing and 235/60-15 tires. I also have 2 in lowering blocks.
Indian113 is offline   Reply With Quote
Old 10-02-2010, 09:31 PM   #5
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: rear end
I'm using a '73 Chevelle wagon rear under mine.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 10-02-2010, 11:30 PM   #6
Wvgearhead
Re: rear end
Ford EPLODER 8.8
Wvgearhead is offline   Reply With Quote
Old 10-03-2010, 04:36 PM   #7
lazypineapple
lazypineapple's Avatar
Re: rear end
Mid 70's car
read here
http://www.chevytrucks.org/tech/rear_ends.htm
lazypineapple is offline   Reply With Quote
Old 10-04-2010, 04:10 PM   #8
Dan Bowles
AD Addict
Re: rear end
Skip the S10. They are too narrow, even in 4x4 unless you can get a ZR2. Camaro is OK. S10 4x4 needs spacers or deeper wheels. Search for Mongo's Garage, he had a list.
Dan Bowles is offline   Reply With Quote
Old 10-05-2010, 04:19 PM   #9
53lochevy
53lochevy's Avatar
Re: rear end
Put a 9-inch in it with 31 inch splines, out of 79 f150 the passenger side is perfect and only have to cut the drivers side. Running 10-inch rims in back with 8 in front... 265/60r15 in the back custom ordered them with 3-inch white wall.. If you gonna put some muscle in the car go with the 9-inch...and slammit with air ride.
53lochevy is offline   Reply With Quote
