10-02-2010, 01:03 PM | #1 |
for all you guys wishing you had a different lug pattern
took me an hour and a half to do in shop on one of the bridgeport mills.
indicated the the center of the the bearing race in the center of rotor, popped the old studs out. drilled and spotfaced new holes. the new bolt circle is within .0005 of being perfect with the hub. so my wheel will be rolling nice and smooth down the road. and yes i know they arent centered in between the previous holes, because theres a gusset there, you can see in the picture. i changes them from 5x5 to 5x4.75 |
10-02-2010, 01:31 PM | #2 |
Re: for all you guys wishing you had a different lug pattern
Well done. Looks great.
That is exactly how we changed the bolt pattern on our '63 Tempest (went from the production 4.5" to a more typical 4.75"), except that we "spotted" through an existing A body drum to mark the locations. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-02-2010 at 01:34 PM. |
10-02-2010, 01:45 PM | #3 |
yea, whatever gets the job done. hopefully these rotor will last for a while hahaha
10-02-2010, 02:21 PM | #4 |
Garage wrench
awesome work man!
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
10-02-2010, 02:24 PM | #5 |
GoatLube Experss
looks good, are ya do'n the rear also ? I put a 9" ford in my MonteCarlo and had the axles and rotors redrill'd to the chevy pattern , they had to offset mine just you did . 2 yrs now, still hold'n up good .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
10-02-2010, 03:12 PM | #6 |
Formerly- 1972SuperCheyenne
Sweet man, nice work!!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
10-02-2010, 03:15 PM | #7 |
Location: Where I come from, it's cornbread and chicken...
very nice
10-02-2010, 03:25 PM | #8 |
thanks guys, i dont need to do that for my rear, mines narrowed with custom moser axles. the only thing i might to is drill them to 5/8 for 5/8 studs for racing.
10-02-2010, 06:17 PM | #9 |
TUKE-NoBullChit Customs owner
ya do know 73 chevy van, only 73, had 5x4.75 pattern and is direct bolt-on for our trucks right? right?
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now) http://www.facebook.com/#!/nbc.customs |
10-02-2010, 08:19 PM | #10 |
10-03-2010, 12:12 AM | #11 | |
Posted via Mobile Device |
10-03-2010, 01:04 AM | #12 |
yeah i was sayin that exactly
10-03-2010, 11:24 AM | #13 |
10-03-2010, 03:46 PM | #14 | |
Not true. The 71-74 G10 vans all had 5x4.75. The 71 & later G20 vans had 5x5. Late 74,early 75 is when the G10 vans started using the 5x5 pattern. I have done extensive research on this & the bearings are different between the two patterns. How did you put them on your truck? Thanks for any info. Brad
55 Chevy small window. 66 FJ40 LandCruiser. 64 Chevy Van,350/350 72 Chevy 10 Van,short wb,454 78 Chevy 10 Van,short wb,350 72 Chevy Malibu 350. 77 Chevy Suburban. Silverado 20 Trailering Special.454,turbo400. |
10-02-2010, 10:35 PM | #15 |
Badass
what wheels you planing on putting on your truck
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
10-03-2010, 12:01 AM | #16 |
10-03-2010, 03:28 AM | #17 |
BAD BOW-Silverado XST
Well, that's one way to fit S10, car and Vette wheels.
10-03-2010, 12:35 PM | #18 |
nice tempest
1979 GMC Sierra Classic Freshly lowered 5 inches |
10-03-2010, 08:44 PM | #19 |
Thank you. They are a pretty crazy little car, with the MOPAR bolt pattern, LH threads on the left side of the car, and the trans/transaxle in back. Lots of fun, though - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-03-2010, 07:33 PM | #20 |
I too have been doing some research...it seems the 5x4.75 van rotors are 1'" thick but use the same bearings as the heavier 1.25" truck rotors. So if you have the 1.25" rotors in theory you could swap to the van rotors, but I'm not sure how the 1.25" calipers will work with the narrower van rotors, or if you could use the 1' truck calipers with the 1.25" spindles....
has anyone actually done the swap?
CHEVY ONLY Last edited by joe231; 10-03-2010 at 07:34 PM. |
10-03-2010, 11:30 PM | #21 |
Yea im not sure which years but some caprices with 10 bolts late 70s thru early 80s, you can pull the axles and brake hardware from to complete it on the back for cheap. The site is on my favs someplace but a guy in washington state did it to his longbed to run camaro rallies. Ill try and find it and post it up.
10-03-2010, 11:43 PM | #22 |
kieth i had no idea they had mopar bolt patterns
10-04-2010, 04:05 PM | #23 |
10-04-2010, 04:35 PM | #24 |
Yep - 5 hole, 4.5" bc.
That tripped 'em up back in the day, when they were trying to put their hot new tires and wheels on.... Dad was saying WTH? That was after you managed to get the lug nuts loose... (lol)
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-05-2010 at 02:45 PM. |
