10-03-2010, 12:35 PM | #1 |
question about blazer door mirrors
mine vanished off the pass side door the bracket is there the other part fell off ..I saw a drivers side one on ebay can I remove the mirror part and put it on the bracket ? stupid question but hey !
10-04-2010, 09:50 AM | #2 |
SWB 4x4 Collector
Re: question about blazer door mirrors
Do you have the rectangle stainless sport mirrors? If so, there should be a inner bracket that goes inside the door and if your mirror vanished, you will probably need to dig it out of the bottom of the door with the door panel off, and hold it up in place while screwing another mirror into place. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-04-2010, 10:29 AM | #3 |
I have bought mirrors more than once..I tend to brake them on the trail..anyway the inner bracket/plate comes with a new mirror
http://www.classicparts.com/1970-72-...info/58%2D121/ Not OEM but they are nice
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
10-05-2010, 12:12 PM | #4 |
Back in the sticks
But the old style ones don't
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
10-08-2010, 09:00 AM | #5 |
Workin to live...
I have the sport mirrors with the bracket on the inside of the door too. I actually used some silicone adhesive on the backing plate inside the door, so if I every need/wanted to remove the mirror, I could without taking off the door panel.
Be sure to check the mirror before installing them. Mine actually came off as I was driving down the road, where the square mirror part adjusts on the post.
Jason |
10-08-2010, 08:21 PM | #6 |
2WD Jimmy
[QUOTE=Cap'n Hook;4230269]I have the sport mirrors with the bracket on the inside of the door too. I actually used some silicone adhesive on the backing plate inside the door, so if I every need/wanted to remove the mirror, I could without taking off the door panel.
Thats actually not a bad idea. I think Id use Automotive Goop brand, its the strongest Ive ever seen. You sure wouldnt want to get any on the threads of the screws though... it would likely be permanent. |
