02-27-2003, 01:04 AM | #1 |
Battery, Alternator, or something else.
ok when my truck is idling the volt gauge shows good well over the 13 mark, but the more electrical stuff i turn on the lower it gets. like at night with headlights, that brings it way down, and so does the heater fan on high. and when the lights are on i can tell they dim noticeably when turning the fan on or something, they just don't look as bright as they should be. the needle will get way down on the gauge in the bad zone with accessories on, but with nothing on it shows good on the gauge. the belts are all tight. the truck starts good, not like the batt is weak or anything. except for yesterday when i left the lights on for eight hours whille at work. the clock in the truck stopped at 11:30 and it was about 6:50 when I got to work and cut the truck off, so thats what, about 4 1/2 hours till batt went compleeetely dead? i got a boost and its just like it was before. so what do you guys think? batt, alt, or some other unidentified major malfunction?
ohh and the gauge will pick up when you get up some speed goin dow the road. |
02-27-2003, 05:12 PM | #2 |
I'm back with 2nd truck!
Sounds like the alternator is not coming on soon enough. The alternator has a internal regulator that comes on at a certain RPM. Also if you have alot of accessories like stero system with amps, crossovers, etc. you may need a larger alt. Also might check the belt for wear as well.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
02-27-2003, 05:25 PM | #3 |
You can also bump your idle up a little, that may help with alt. output. I have thought alot about getting an overdrive pulley. Makes the alt turn faster creating more output at idle. I will do it soon. The pulley is like $30-35. Cant remember the manufacturer.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
02-27-2003, 08:06 PM | #4 |
~THE SILVER BULLET~
its your alternator.
~1980 c10 chevy scottsdale~ ~2.5/4 drop 305/th350c~ |
02-27-2003, 09:55 PM | #5 | |
I love goooooold!
These are REQUIRED and if your truck does not have them, install them. They are 3.99 each, I used two of them and now my truck no longer does what yours does. Jeff
"Musha ring dum a doo dum a da Whack for my daddy-o Whack for my daddy-o There's whiskey in the jar-o." |
