Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-04-2010, 11:02 PM   #1
68C10HotRod
68C10HotRod's Avatar
Project - FrankenBurb in NE
Well, I finally decided to post some info about a '72 Burb I got back in 2009. Got it on EvilBay & was a little disappointed after she got here so it sat until this year. Promised my wife it would either be drivable or gone this year. Was really hoping it wouldn't be that hard to get into "driver" status but that's starting to look like a long dark tunnel - we'll see.
The good - check out the SPID!! Some decent options that made me want it & decent looking in the pics. 400BB, TH400, AC overhead, chrome bumpers, Posi, power steering, gauges.
Now that I've hopefully peaked your interest ........
Bryan
'52 Bel Air 2dr HT - in pieces
'68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin
"And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery)
68C10HotRod is offline   Reply With Quote
Old 10-04-2010, 11:06 PM   #2
63chevyll
gets board easy.......
63chevyll's Avatar
Re: Project - FrankenBurb in NE
that looks pretty cool,
I like it. body looks good, hope its not covering up the bad stuff
63chevyll is offline   Reply With Quote
Old 10-04-2010, 11:14 PM   #3
Number98
Prestige Worldwide
Number98's Avatar
x2
Number98 is offline   Reply With Quote
Old 10-04-2010, 11:13 PM   #4
68C10HotRod
Now for the BAD:
She's got just a "little" rust. Oh well, at least it's got those nice options right!!
Well, after some checking. How come the ps tire spins backwards when you spin the ds forward - DOOH - 1 legger. WTF, someone stole the posi!!! Opened it up to confirm. Found a 68 3.73 open section & housing - funny, it's got 5-lug axles. How come the drums are worn only 1.5" of the 2" & same with the pads only the opposite side. Someone stuck the longer 5-lug axles back in the shorter housing. Great, that rear end is ALL jacked up.
---Old---
Let's take a look at that engine suffix code - T0510TCM. Hmmm, can't find that under the 396/402 reference - let's look under T**. WTF is a 1970 366 from a 60 series doing in there???
---Correction---
I have to correct that last part - suffix code is T0510TLM which IS the CORRECT 402!!!! NICE!! Now I have an EXTRA.
---End of Edit---
And the work begins .............
Bryan
Old 10-04-2010, 11:25 PM   #5
68C10HotRod
The OE wire harness made me cringe wondering if it would just burst into flames after I got some work done so I ordered the AAW harness & started to remove the old one.
Also decided I want about a 4/6 ride height when it's running so I bought the 5" kit with super track bar from ECE & have started with that install since the rear end is out right now. Had some C-notches that I was going to use on the 68 but since it's 2/4 currently & they weren't going to be used right away - Jake, my 13yo son helped me get those started this weekend.
Since I like to make extra work for myself - I unknowingly put the Burb about 5' out of the reach of my plasma cutter so all the rivets & notch work had to be done with a die grinder - about 20x longer than it needed to be. Only got the DS notched & installed with the 4 bottom bolts. Still need to drill the side 4.
Bryan
Old 10-04-2010, 11:41 PM   #6
68C10HotRod
I've got a decent parchment seat in my 68 so when Randy (teeitup) had a pair of rear seats in parchment a while back, it only seemed right to grab those. They were a little nasty ......
but, I HAVE to keep telling myself - I just want a decent DRIVER!!!
They didn't clean up too bad .....
Forgot to take DIRTY pics of the 2nd row but after cleaning it decided no one would believe me if I didn't at least get some of the 3rd row before I did it. This little seat project actually brought my wife out of the house & she worked right along with Jake & I on these. BTW, she really doesn't like the Burb but she indulges me so I can't complain one bit.
Second row is really nice (think it was actually the 3rd before but it will be the 2nd now). Anyone notice the ONLY marks I couldn't get rid of ....
Maybe this is a little easier to see. Sharpie just looks bright pink when you get the top layer of black off!!
So it will have 3 rows of parchment seats when she's back on the road. Notice the SPID code is only for 2nd row seats. Figured what's the use in having a Burb if you can't load that baby up with people & stuff.
Bryan
Old 10-04-2010, 11:43 PM   #7
jbclassix
Junk Yartist
jbclassix's Avatar
Nice!!!!!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-04-2010, 11:53 PM   #8
63chevyll
63chevyll's Avatar
I hear those 366's are real boat anchors,
bummer man
Old 10-06-2010, 12:48 AM   #9
68C10HotRod
I made a score today that should correct the 366 problem the CORRECT way. Got home late today with it.
It feels good to set this part of the Burb on the right path. Thanks for the interest guys. We're having fun working on it & hope to be driving her soon. The rust might very well get temp patches right now & the real deal next spring. It's all going to depend on the 454/400 swap in the 68 C10 - FUN.
Bryan
Old 10-06-2010, 04:40 PM   #10
jbclassix
Junk Yartist
jbclassix's Avatar
mmmm big blocks. don't throw that 366 out just yet. It has the same stroke as your 402. 366 396 402 and 427 all used the 3.76 stroke. cheap insurance if you need short block parts.
-Jeremy
Rebuilding an NP205
Old 10-09-2010, 08:44 PM   #11
68C10HotRod
Got some more work done the last couple days. C-notches DONE. Upper shock relocation mounted. Old track bar cut out - bolt was RUSTED to the bushing so bad it looked almost solid when it was cut out.
Too bad I don't have the rear end I was supposed to pick up this weekend!! Would have been real nice to have the rear, 5" springs & shocks in there with it sitting ON THE GROUND again. Hopefully very soon.
Making progress but it's just never quite fast enough for me.
Bryan
Old 10-09-2010, 08:58 PM   #12
Number98
Prestige Worldwide
Number98's Avatar
Good progress man
Old 10-21-2010, 05:21 PM   #13
68C10HotRod
Sorry for the lack of progress. I scored a 1-leg 3.07 (just in case) a couple weeks ago but THIS was scored yesterday for $120 & some gas $. Can't wait to blast, shoot & install. Have all new brake parts (less drums) & probably put new seals in while I'm at it. Any recommendations to shoot the housing with - POR-15, puff cans (brands?), other?
Bryan
Old 09-28-2011, 10:29 PM   #14
68C10HotRod
Well it's been a LONG time since I posted any progress at all. The Burb is wired enough to fire up & run in the drive but still need to wire the front (headlight) harness & the run, turn, brakes in the back.
Went to a swap meet last weekend & picked up these. A little rough but not too bad. Spent about an hour or less hitting the right one with 220 sandpaper. Thinking about polishing the sides & painting between the grooves.
The 402 is about ready to be machined. Thought I'd mock up a few things acquired for it.
Bryan
Old 10-15-2011, 06:00 PM   #15
68C10HotRod
The 402 is getting built & almost done. He's waiting on me to bring him the intake (getting Ceramic Coated) & he'll finish putting it together. He discovered someone put a steel crank in it & the journals needed polished, the rockers were pretty wore out & he thought we should move from the 3/8 to 7/16 push rods & guide plates, a few valves were a little bent & needed new ones, but the bore took .030 over with ease. It should be back next week so look for pics.
Bryan
Old 10-16-2011, 05:28 PM   #16
Slinger60
Slinger60's Avatar
I'll be watching this thread. Can't wait to see that bad boy big block in it. And those seats cleaned pretty nice too. Nice work so far.
1969 C10 LWB GMC.
1970 K5 Blazer
1971 K10 Burb
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=529970
Shawn
Slinger60 is offline   Reply With Quote
Old 11-30-2011, 11:00 PM   #17
68C10HotRod
Here's a little teaser for anyone watching. The air cleaner is a hint to what's happening with the valve covers - it was chrome.
Edelbrock Air Gap intake (ceramic coated), Sanderson headers (cc), ARP bolt kit, aluminum water pump, red to eventually match the Burb.
Bryan
Old 12-01-2011, 02:15 AM   #18
BurnoutNova
BurnoutNova's Avatar
If your looking for axles Speedway in Lincoln has 5 lug axles that will go right in there... and be the correct width.
BurnoutNova is offline   Reply With Quote
Old 12-01-2011, 03:40 PM   #19
Bigblueburban
Bigblueburban's Avatar
That motor looks nasty I'll be checking in on this one. I'm not a fan of red but I love this one in red and the motor painted. Looks great
Bigblueburban is offline   Reply With Quote
Old 01-09-2012, 04:50 PM   #20
68C10HotRod
Well I'm hoping to get this installed today or tomorrow while the weather is still SO NICE. Just thought I'd show it off this way because the engine compartment hasn't really been cleaned up or painted yet.
Bryan
Old 03-05-2012, 04:46 PM   #21
Riveted1
Tasty Cakes!
Riveted1's Avatar
Wow don't know how I missed this one! Any more progress?
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-12-2012, 09:24 PM   #22
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Hey Brian,
Looks like the progress is headed in the right direction on the 'burb. I'll have to give you a call this weekend or stop by and see how things are going. keep up the great work buddy.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 04-14-2012, 10:10 PM   #23
68C10HotRod
Well there's no pics but I have made a fair amount of progress. Installed motor & got the important stuff hooked up to fire it for break-in. THAT was FUN!! Now the headers are back on & all the front end wiring is done. The rear is wired but it's just crimped together inside the rear - but it does all work. Had a draw on the battery that sucked it dry overnight - ended up being inside the Alternator. Got some rubber on it & painted the rallys deep red to match the body. Working to install my 52 Bel-Air hub caps at some point. Been working on aftermarket gauges for now. Sticking with OEM speedo but putting aftermarket tach in the fuel gauge location. Also aftermarket (fuel, water temp, oil press, batt) in the lower 4 holes. Hoping to drive it over for exhaust next week so I can finally get it on the road.
She still needs a lot of things done, but I'm just dying to drive it so I'll have to whittle away at the little things & just get it on the road.
Stealthy, Wahoo swap meet is Apr 22. I'll probably go. LMK if you want to.
Bryan
Old 04-17-2012, 07:43 PM   #24
stealthy '69
'69 Chevy SWB
Sounds good to me. I'll try to give you a call Friday or Saturday and work everything out. We taking the 'Burb?
Matt
Old 02-23-2015, 09:42 PM   #25
twistedchevy
Bump
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
