Choosing a shaved door kit...
So I finally got some money to finish up my doors. Got everything shaved and now just looking at shaved door kits.
I was thinking of going with this autoloc kit but read it only comes with 35lb solenoids, is that enough pull for our doors? http://cgi.ebay.com/ebaymotors/SHAVE...item587fb5329f I also found this spal kit after reading a recommendation over the above kit. This look any better? http://cgi.ebay.com/ebaymotors/SPAL-...item3a5f21f800 I looked at the kits from avs but they are out of my price range. If both those choices are bad, are there any other kits you'd recommend over the above two? |
![]() Join Date: Dec 2008
Re: Choosing a shaved door kit...
I've been looking at these shaved door handle kits for a while and reading about them. Just keep in mind, these trucks have big ol' doors. Takes a lot to move them, and as far as one over the other, I really couldn't advise or suggest. But the more capacity, the better off you'll be. And I don't think fleabay is your best place to look. Summitracing may be
But that's just my two cents. Last edited by nbpro; 10-05-2010 at 12:42 AM. |
#3 | |
Any other suggestions? Edit: This kit looks nice http://www.summitracing.com/parts/VIA-80158-35/ Last edited by bigwheel15; 10-05-2010 at 01:05 AM. |
This is not from personal experience but I would leave the key lock in place in case of electrical failure had a cousin run it to this with his S10 was locked out
![]() Last edited by nbpro; 10-05-2010 at 01:12 AM. |
Already shaved the key hole, didnt have the key for it when purchased. Ill be running a manual entry cable hidden somewhere.
In the Forgotten far North.
![]() Join Date: Jul 2007
Check out magic touch at http://www.lafranceautoworks.com/
The window mounted sensors are kinda sweet.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Old Heap Driver
I have shaved doors on my S-10, never again. BUT! I recently at the suggestion of a good friend, swapped out my solenoids for a kit from AVS. The AVS kit is awesome! They're made for the vehicle, not a universal deal, although they do sell a universal kit.
http://www.avsontheweb.com/home.php?cat=527 You won't be disappointed, my S-10 doors now open the first time every time. Also, be sure to run some cables from your battery to a pair of charging post somewhere under your truck. Place them in an accessible location for a jump box or jumper cables should your battery die.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
AVS kit is what i have ben looking at
When I purchase my kit it will be the AVS geared actuators.
![]() Join Date: Apr 2009
good info
Happy to be here
![]() Join Date: Mar 2000
And AVS is a Forum Vendor. Take a look in the Vendor Marketplace or Suspension Forum for AVS Specials.
Well after looking over the avs site for about the 20th time im REALLY considering going with their universal kit for $180. Figured they extra bucks are worth a product ive yet to hear a bad word about.
Oh and a question to the people here with shaved doors, are the door poppers necessary or are we fine without them? |
Old Heap Driver
I have them on my S-10 and would say yes, you do need the popper.
#14 | |
Fernando Project "FATBOY" build thread The key to happiness is having dreams. The key to success is making your dreams come true. |
#15 |
Happy to be here
Yes they are needed. I had shaved handles on a Camaro once, and used a GM stationwagon tailgate switch to unlock the doors. I mounted it under the rear fold down license plate. Turn the key to the left for driver door, and to the right for passenger door.
All was cool till I parked close to a fence on the passenger side. The slope of the driveway had the car leaning toward the fence. Even though my door would pop quite a bit, the slope of the drive created enough pull that I could not pop the door open. Get the poppers... ![]()
#16 |
Looks like I am by myself but I say you don't need poppers IF you are also installing bear claw latches. They pop hard enough to push your door open some. If you are using stock latches then yes you will want them.
#17 |
a fool with no money
I didn't use a kit and my handles are shaved, but not the locks. I altered the latch so when I stick the key in the lock, and turn it to the unlock position, it releases the latch. the seals provide enuff push to "pop" the door open. It's all mechenical... no worries about dead batteries, or hidden switches. Very Old Skool young'uns!
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
#18 | |
#19 |
That works but you still got the lock there uglying everything up.
