Old 10-05-2010, 09:01 PM   #1
81 Redhead
81 Redhead's Avatar
Question Wish I was a Mechanic. Carb question?
Any help will be greatly appreciated. My question is this...
Will this - http://www.jegs.com/i/Edelbrock/350/...oductId=743633
make this - http://www.edelbrock.com/automotive_...erformer.shtml
fit a stock intake manifold on an '81 C10, 350?
Rock out with your, uhhh.... Hang out with your wang out!
81 Redhead is offline   Reply With Quote
Old 10-05-2010, 09:54 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Wish I was a Mechanic. Carb question?
If you have the stock spread bore manifold you will need a adapter such as this; http://www.jegs.com/i/Trans+Dapt/969/2034/10002/-1
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 10-05-2010, 09:56 PM   #3
presleyhome
I sent this at the same time as restrorob. His suggestion will work too!
This is what Edelbrock says you need to install that carb on a Qjet manifold.
http://www.jegs.com/i/Edelbrock/350/2696/10002/-1
Jim P
1981 Sierra C2500 LB Fleetside, 350M, Th400, QJ, 14bolt 10.5" rear.
presleyhome is offline   Reply With Quote
Old 10-06-2010, 08:07 AM   #4
panicrev613
the edelbrock 2696 is a better piece. carbs work on vacuum signals, the transdapt open design can cause confusing signals to the carb and it'll act funny at certain points in the rpm and throttle opening.
i work at a family owned speed shop for 20 years and sold both products. we just stock the edelbrock part for this reason.
panicrev613 is offline   Reply With Quote
Old 10-06-2010, 10:12 AM   #5
nikwho
nikwho's Avatar
So, I read on my edelbrock carb instruction sheet that you are not supossed to use the open adapters. Why is this? Does it create vaccume leaks? Will it hurt the carb?
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 10-06-2010, 02:15 PM   #6
Cue-Ball
Cue-Ball's Avatar
It doesn't create vacuum leaks or hurt the carb, but it causes the vacuum signal, which is what the carb uses to meter fuel, to be erratic. So you get a carb that's difficult to tune for part throttle and around town driving. The spacers with the holes keep the air flowing smoothly which gives a better vacuum signal and helps part throttle response and tuning.
Cue-Ball is offline   Reply With Quote
Old 10-06-2010, 04:58 PM   #7
81 Redhead
81 Redhead's Avatar
So I don't need the spacer, but the adapter instead...
Thanks, y'all. You guys are the best. I LOVE this forum! Lol.
Thanks for all the input! Hoping to get this thing on the road soon. Driving it around at work on a ranch at the moment. lol
